PPP cannot connect to my Wi-Fi network
(01-30-2022, 01:19 AM)Luziferus Wrote:
(01-29-2022, 09:04 AM)Luziferus Wrote: I've searched Matrix and Telegram groups for anyone with same issues, but it seems I'm currently the only one so I assume it is probably related to my Wi-Fi SSID setup. But since I have also a ROCK Pi 4B running without issues at home, all other devices, too, I think this might be connected to the network manager of PPP (Manjaro Linux).
Is fixed by switching to WPA2 on my router. It was using WPA3 so seems like PPP's network manager or the hardware (?) does not support WPA3 (yet).
i had issues too with my wpa3 only ssid, the problem is in wpa_supplicant which is used by network-manager, solved switching wifi_backend to iwd (you have to install it, enable the service...https://wiki.archlinux.org/title/NetworkManager#Using_iwd_as_the_Wi-Fi_backend), wpa3-SAE works flawlessly now for me, at least on Arch linux arm, which btw also solved the charging issue so i quicly got rid of the preinstalled manjaro
RE: PPP cannot connect to my Wi-Fi network - by ironashram - 01-30-2022, 06:46 AM
  [Solved] Connect PPP to PC via USB for data transfer ? libresurf 1 1,226 09-20-2022, 12:31 PM
Last Post: libresurf
