HP_JACK not activated at power-up
(06-30-2016, 12:09 AM)gbjensen Wrote: A manual short circuit of pin 3 and 4 reset the HP_JACK audio output. when the short circuit is removed is the audio output activated.
I will now see if I can write an app or a small script to do this (setting / resetting a GPIO pin controlling a analog SW device and thereby make the short circuit)
Have you figured a way to make this work yet? As the audio jack loses connection on reboot or even shutting down and reopening the app using it in Android, I also need to figure a way to keep connection with it without removing and plugging back in to the audio jack. I am trying to use the pine for Square POS instead of a tablet.
HP_JACK not activated at power-up - by gbjensen - 06-29-2016, 02:38 AM
RE: HP_JACK not activated at power-up - by xalius - 06-29-2016, 07:55 AM
RE: HP_JACK not activated at power-up - by xalius - 06-29-2016, 12:47 PM
RE: HP_JACK not activated at power-up - by toyshop - 05-08-2017, 10:59 AM
  Airmouse only works on AC power? Chisel_86 4 7,060 08-31-2016, 07:16 PM
Last Post: pfeerick
  power button - tactile button make and model number DevDorian 12 14,303 07-14-2016, 01:02 PM
Last Post: cpeterlotz
