Steps Counter Reset
for me, it's never resets in the middle of the day. it's always at midnight...
the only case when it resets - after device reboot (e.g. by a long press "Power" button. well, the only hardware button).
could it be the case?
as an indicator of rebooted InfiniTime you may use a fact, that Notification are also cleared.
so, if you see the zeroed steps counter, then check the notifications.
p.s.: sometimes (noticed it only once in the last several months) InfiniTime counts much less steps than usual...
also, @drh , if the issue is not one-time, you could log the issue to InfiniTime repo so it will be visible for developers.
Away
Steps Counter Reset - by Frowzzen - 12-27-2021, 08:39 PM
RE: Steps Counter Reset - by ITCactus - 12-28-2021, 02:13 PM
RE: Steps Counter Reset - by drh - 01-19-2022, 02:42 AM
RE: Steps Counter Reset - by ITCactus - 01-19-2022, 05:01 AM
  [question] How does the step counter log data? arock 1 1,459 06-20-2022, 04:33 AM
Last Post: wibble
