Rock64 <--> Rock64 Serial Connection
Quote:I'm trying to troubleshoot a booting problem with my Rock64 with an openSUSE Tumbleweed install on an eMMC.
If an SD card is an option, this might be easier.
Quote:When I cat /sys/firmware/fdt while using my USB UART the output is garbled.
I'm not sure cat handles unknown bytes correctly, or it's incorrectly trying to escape data. Also I am not sure how cat will handle pauses in transmission (blocking vs non-blocking, 7-bit ASCII vs 8-bit ASCII vs UTF-8, etc). Checkout socat and the options it offers: https://stackoverflow.com/questions/2637...connection
Quote:When I hookup the tx > rx and rx > tx , both Rock64 lockup. So, is there a way to use the 2nd Rock64 in this manner?
Lock-up is likely quite bad. Check they have a common ground. Even if they have a common power source, by the time it has been through a USB cable and power modulator they may drift.
RE: Rock64 <--> Rock64 Serial Connection - by barray - 12-23-2021, 09:27 PM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 348 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,480 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,784 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,293 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 365 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,963 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,583 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,167 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 776 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 976 10-07-2022, 07:50 PM
Last Post: rookie_267
