Mobile internet via cellular network mostly not working
The battery drainage is extreme indeed. According to a little test I did, the Pinephone can remain in standby for only five to six hours with ATTR set to "on" and more than 34 hours with "auto" (see below).
Of course you won't notice the difference as much if you actually use the phone because that will drain the battery in no time with both settings.
Unfortunately, I will have to stick to the "on" setting since otherwise the modem will crash so often that the phone is actually unusable.
Or does anybody have a fix for BOTH problems so that I would not have to choose between short battery life and a permanently defunct modem?
        ATTR{power/control}=
hours  "auto"  "on"
0        100%   100%
1          93      82
2          91      60
3          88      42
4          85      26
5          83      15%
6          80    OFF
11        54%
15        43
23        41
28        19
30        14
31        11
32          8
33          6
34          4%
35        OFF
RE: Mobile internet via cellular network mostly not working - by Anna - 02-26-2022, 11:01 AM
Exclamation The internal speaker stops working anonymous 6 1,297 01-17-2024, 05:53 PM
Last Post: anonymous
  APN settings not working with new operator SIM card user641 1 1,104 03-01-2023, 04:43 PM
  Possible Solution for Microphone Not Working Ferriah 0 1,004 02-13-2023, 01:09 PM
Last Post: Ferriah
  Not connecting to cellular network car46999 18 7,968 01-30-2023, 12:06 AM
Last Post: car46999
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 1,685 01-07-2023, 09:36 AM
Last Post: dcarvil
Exclamation No modems were found: No mobile data, no 2G anonymous 2 1,478 12-26-2022, 06:46 PM
  very slow processing of MMS received via Ting (T-Mobile) treebeard 6 2,728 12-01-2022, 09:18 AM
Last Post: traut
  Squeekboard stopped working Zebulon Walton 2 1,273 11-24-2022, 08:41 PM
  need help with downgradin network-manager Ferriah 0 689 11-07-2022, 04:51 PM
Last Post: Ferriah
  DNS Problems with Mobile Data arno_nuehm 29 17,793 10-29-2022, 09:16 AM
Last Post: treebeard
