Rock64 kernel panics
(10-13-2021, 12:49 PM)clay Wrote: I booted into a fresh Armbian install and ran the board with no USB devices attached. I was optimistic at first, because it ran overnight (around 10 hours). But then it crashed. I tried bringing it back up multiple times, but after that first crash, it only lasted about 5-15 minutes each time before it crashed again. I'm not sure if it was just coincidence that it ran so long at first, or if there is, indeed, something related to USB.
Unfortunately, all the other 5V/3A power supplies in my collection have micro USB connectors, not the barrel connector needed for the Rock64.
Thanks again for the help troubleshooting!
Ok. I asked you a number of questions above and you've ruled some of them out. What I'm going to suggest now is remove any attached devices including monitor and any USB devices, remove the board from the case and use Armbian as you boot OS. That's exactly my setup here and my board runs flawlessly 24/7 and has done for nearly three years.
I've suggested to many users here before about swapping out the power supply as a first course of action and in many cases that's worked. To be honest I don't trust those official power supplies. Just for testing purposes the board will boot and run under a 5v 2amp supply but not under heavy load. I've done that myself. You might have one of those lying around. They are popular with the likes of IP webcams etc. Check and see first before sourcing a replacement 5v 3amp power supply. Until you've ruled that out you could waste hours troubleshooting this problem.
You can of course check the supplied voltage to the board with a multimeter. Also if I'm not mistaken Armbian will report under voltage instances. If you run the dmesg command it should yield some information.
Rock64 kernel panics - by clay - 10-11-2021, 09:43 AM
RE: Rock64 kernel panics - by t4_4t - 10-11-2021, 01:24 PM
RE: Rock64 kernel panics - by clay - 10-11-2021, 04:08 PM
RE: Rock64 kernel panics - by Rocklobster - 10-11-2021, 06:49 PM
RE: Rock64 kernel panics - by clay - 10-11-2021, 11:24 PM
RE: Rock64 kernel panics - by t4_4t - 10-12-2021, 03:07 AM
RE: Rock64 kernel panics - by tllim - 10-12-2021, 08:33 PM
RE: Rock64 kernel panics - by clay - 10-12-2021, 12:51 PM
RE: Rock64 kernel panics - by tllim - 10-12-2021, 08:34 PM
RE: Rock64 kernel panics - by clay - 10-13-2021, 12:49 PM
RE: Rock64 kernel panics - by Rocklobster - 10-13-2021, 06:30 PM
RE: Rock64 kernel panics - by tllim - 10-14-2021, 12:46 AM
RE: Rock64 kernel panics - by clay - 10-14-2021, 05:07 PM
RE: Rock64 kernel panics - by Rocklobster - 10-15-2021, 04:15 AM
RE: Rock64 kernel panics - by clay - 10-17-2021, 05:20 PM
RE: Rock64 kernel panics - by Rocklobster - 10-17-2021, 06:30 PM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 340 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,466 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,781 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,291 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 364 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,963 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,582 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,163 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 776 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 974 10-07-2022, 07:50 PM
Last Post: rookie_267
