well, I have a nice GUI, now what? Help needed please
(06-23-2016, 08:50 AM)tim.bob.mason@gmail.com Wrote:
(06-23-2016, 07:25 AM)MarkHaysHarris777 Wrote: It looks like the desktop did not build (or is not being displayed at the correct resolution... is it possible that the tool bar is 'above' the top of the screen?
Are you using hdmi  1080p60  720p60 ?  other?
Did you try rebooting?
yep, tried rebooting, and yep, its possible
(06-23-2016, 08:50 AM)tim.bob.mason@gmail.com Wrote: yep, tried rebooting, and yep, its possible
changing the 'Aspect' on the tv has found the tool bar (at the bottom), so now I have a grey bar, with a green square to the left and a trashcan to the right.....
That's great, well there's supposed to be a bar like that at the top...
... go into your TV settings and check ALL of the menu options and sub menu options... see if you can change the ratio 16:9 , 1080p60 and really... try everything.
By the way,  any modern LED hdmi display (Samsung, LG, HP, etc) that supports 1080p60 will work fine;
RE: well, I have a nice GUI, now what? Help needed please - by MarkHaysHarris777 - 06-23-2016, 09:13 AM
  Xubuntu help needed Fox7799 3 4,436 06-22-2016, 08:49 AM
Last Post: MacFizz
