display blinks on and off when not on charger
(09-06-2021, 04:03 AM)jpaulbiss Wrote:
(09-06-2021, 12:26 AM)kqlnut Wrote:
(09-05-2021, 03:40 PM)jpaulbiss Wrote: You were correct; software related. I flashed Mobian to a SD card and it works with out being plugged in. Smile  Now to find an OS that has the apps I use, which isn't many. Signal, Wire, the difficult one to find outside of Android is the ones for online banking.
Glad to hear it works! For Signal your best bet is probably Axolotl which has been packaged already for Mobian (not in the repos though I think) and Manjaro/Arch (AUR, repackaged from the Mobian version), although it doesn't work properly at the moment due to changes on Signal's side. Banks use their proprietary apps I guess which will most likely not be available for Linux, but maybe you could get it to work with Anbox.
Mystery solved. Smile
Just a follow up... I flashed the latest vers of the OS using jumpstart and  balenaEtcher, the issue dissapeared. updating the software alone has no effect. Thanks everyone for the help and I apologise for being such a grunpy old fart.
RE: display blinks on and off when not on charger - by jpaulbiss - 09-18-2021, 06:01 PM
  [Article] Star64 JH7110: Power Up the Display Controller with U-Boot Bootloader lupyuen 0 761 09-02-2023, 10:13 AM
Last Post: lupyuen
  [Article] RISC-V Star64 JH7110: Inside the Display Controller lupyuen 2 1,061 08-23-2023, 05:08 PM
Last Post: lupyuen
  Article: ST7789 Display with LVGL Graphics on Apache NuttX RTOS (PineCone BL602) lupyuen 0 921 03-31-2022, 09:31 PM
Last Post: lupyuen
  PinePower 65W GaN Charger, bad EU addapter talpa 1 1,764 11-20-2021, 05:21 PM
Last Post: bharwargl
  PinePower 65W GaN Charger, where is the alleged switch? biketool 1 2,112 09-28-2021, 09:46 PM
  How to keep the display of the 120W PinePower turned off? pinepoweruser 4 4,319 08-04-2021, 12:24 AM
Last Post: kqlnut
  Article: PineCone BL602 Talks UART to Grove E-Ink Display lupyuen 0 1,491 02-18-2021, 09:08 PM
Last Post: lupyuen
  Article: PineCone BL602 Blasting Pixels to ST7789 Display with LVGL Library lupyuen 0 1,462 02-15-2021, 09:03 PM
Last Post: lupyuen
  IPS Display got daamged mstsdt 1 2,937 06-02-2020, 08:17 PM
Last Post: Dendrocalamus64
Exclamation Idea, smart display, and TV box? mzs.112000 2 3,714 01-06-2020, 05:20 AM
Last Post: Danct12
