reset to factory default
I'm a new pinephone user. When trying to connect as root, I do use "sudo su" and I gave my PIN code as password.
That work fine. I did some look up as root and exit from root.
Then I changed pas password in order to have my favorite password which is alphabetic. Then I shutdown my phone.
On restart, the pinephone ask my then PIN code as a number. But nor my old PIN does works, nor the sim card PIN. I suspect that changing the password for the main user should be restricted to a numeric sequence in order to be able to answer the PIN code question with the new password.
So, now I'm perfectly blocked and, I thing, the only solution should be to restart from factory setup.
Does somebody knows how to do ?
Regards
Jacques
reset to factory default - by jacques@abstraction.ch - 09-02-2021, 03:47 PM
RE: reset to factory default - by jlucas - 09-03-2021, 04:32 AM
  reset button under back cover, below the camera mruser1 2 1,061 01-02-2023, 08:07 AM
Last Post: wibble
  Help - Factory Reset ?? sej016 4 4,321 12-09-2021, 06:42 AM
Last Post: sej016
  modem and login/reset issues dhawk 1 2,191 06-23-2021, 05:04 PM
Last Post: 33YN2
  Factory image April shipment RRman 2 2,649 05-06-2021, 03:29 PM
Last Post: RRman
  Default Password for New Pine64 KDE Plasma CE? robertb1 3 5,281 02-01-2021, 04:29 PM
Last Post: cybercricket
  default password for Manjaro pinephone Raniyah 1 3,601 11-23-2020, 11:50 PM
Last Post: kqlnut
