PinePhone as DIY SIP Gateway
It used to be possible on the OpenMoko with asterisk. Have a look at chan-quectel which is targeting similar quectel modem modules, and seems a fair starting point:
https://github.com/t4rd15/asterisk-chan-quectel
The trick will probably be sorting out the audio routing/configuration - Megous has the best description I've seen of how the routing works, or at least can work - I'm not sure if the distros are all doing it the same way.
https://xnux.eu/devices/feature/audio-pp.html
PinePhone as DIY SIP Gateway - by Thoams131 - 08-21-2021, 05:57 AM
RE: PinePhone as DIY SIP Gateway - by Thoams131 - 08-22-2021, 07:47 AM
RE: PinePhone as DIY SIP Gateway - by wibble - 08-23-2021, 09:42 AM
  Pinephone won't boot. spha 13 3,034 2 hours ago
Last Post: Richy_T
  Pinephone boot. Richy_T 5 230 9 hours ago
Last Post: Richy_T
  eSIM on PinePhone just_a_q 4 2,763 05-14-2024, 01:35 PM
  PinePhone - boot from microSD laserpyramid 9 966 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 478 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 325 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 111,704 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,999 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 712 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,671 12-28-2023, 07:55 AM
Last Post: MTXP
