Any developments at all?
(09-17-2021, 01:13 PM)tophneal Wrote:
(09-17-2021, 01:08 PM)QuinTeknoLife Wrote:
(09-17-2021, 12:07 PM)tophneal Wrote:
(09-17-2021, 10:50 AM)QuinTeknoLife Wrote:
(09-17-2021, 09:25 AM)tophneal Wrote: this is most recent info regarding installing waydroid on danctnix (arch):
https://fosstodon.org/@xaviers/106936888809418637
and this reddit post has info on installing it to images not using boot/boot.txt, though the pkg link is dead, so the package would need to be grabbed from another repo.
With a little bit of luck, the Wayback Machine might be able to pull the package out of their archive (http://archive.org/web) Tongue
it may not be necessary, just found the new waydroid-image package in the manjaro community repo, so i could be grabbed from there too
EDIT: waydroid command not found gets reported on my tab manjaro install (havent tried pbp yet) and systemctl cannot find the service file for waydroid-container.
waydroid-container? I was under the impression that waydroid was supposed to use lxc or whatever it is called lol. Anyhow, I'm downloading and installing the waydroid package that pamac serves up as we speak, so we'll find out if it'll behave any different on PBP (:
i was going off danct's arch instructions. per a gitlab issue of manjaros, it appears that isnt necessary and a launcher should be available after install
After installing  the package from pamac waydroid-start and waydroid-stop are available as commands, however it seems the kernel modules are not enabled (yet) so I guess I gotta do that first.
[quincy@pbp ~]$ waydroid-start
This script can only be run as root.
[quincy@pbp ~]$ sudo waydroid-start
[sudo] wachtwoord voor quincy:
modprobe: FATAL: Module binder_linux not found in directory /lib/modules/5.14.2-1-MANJARO-ARM
modprobe: FATAL: Module ashmem_linux not found in directory /lib/modules/5.14.2-1-MANJARO-ARM
ERROR: Binder and ashmem nodes not found!
Any developments at all? - by QuinTeknoLife - 08-05-2021, 02:55 AM
RE: Any developments at all? - by tophneal - 08-05-2021, 07:12 AM
RE: Any developments at all? - by QuinTeknoLife - 08-05-2021, 09:30 AM
RE: Any developments at all? - by tophneal - 08-05-2021, 11:18 AM
RE: Any developments at all? - by jiyong - 08-05-2021, 12:08 PM
RE: Any developments at all? - by tophneal - 08-06-2021, 07:09 AM
RE: Any developments at all? - by jiyong - 09-06-2021, 03:14 PM
RE: Any developments at all? - by tophneal - 09-07-2021, 06:21 AM
RE: Any developments at all? - by QuinTeknoLife - 09-17-2021, 08:22 AM
RE: Any developments at all? - by tophneal - 09-17-2021, 09:25 AM
RE: Any developments at all? - by QuinTeknoLife - 09-17-2021, 10:50 AM
RE: Any developments at all? - by tophneal - 09-17-2021, 12:07 PM
RE: Any developments at all? - by QuinTeknoLife - 09-17-2021, 01:08 PM
RE: Any developments at all? - by tophneal - 09-17-2021, 01:13 PM
RE: Any developments at all? - by QuinTeknoLife - 09-17-2021, 01:16 PM
RE: Any developments at all? - by tophneal - 09-17-2021, 01:57 PM
RE: Any developments at all? - by QuinTeknoLife - 09-17-2021, 05:20 PM
RE: Any developments at all? - by poVoq - 09-18-2021, 05:32 PM
RE: Any developments at all? - by tophneal - 09-20-2021, 07:57 AM
RE: Any developments at all? - by jiyong - 11-14-2021, 03:34 PM
RE: Any developments at all? - by jiyong - 11-17-2021, 03:49 PM
RE: Any developments at all? - by jiyong - 01-27-2022, 06:20 PM
RE: Any developments at all? - by jiyong - 01-30-2022, 07:39 AM
RE: Any developments at all? - by jiyong - 02-11-2022, 01:13 PM
