Manjaro Image
Now that we have working LAN, we can link this image here Smile
https://github.com/manjaro-arm/quartz64-...s/releases
The image is updated weekly.
With
pacman -Syu
you can then update it.
Working
  • LAN
  • PCIe
  • USB2
Not Working
  • USB3
  • SATA-Port
  • HDMI
Quote:If there is no battery plugged into the board, the jumper labelled "ON/OFF_BATT" must be in place. If this is set wrong, stability issues such as failures to boot will occur.
Source: https://wiki.pine64.org/wiki/Quartz64#St...tery_Shunt
Thank you Dan!
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
Manjaro Image - by Bullet64 - 07-05-2021, 12:08 AM
RE: Manjaro Image - by zer0sig - 07-10-2021, 07:46 PM
RE: Manjaro Image - by espen - 08-07-2021, 08:59 AM
RE: Manjaro Image - by homerunisgood - 09-21-2021, 03:06 PM
  Manjaro Image June 2022 Bullet64 1 1,707 06-10-2022, 10:14 AM
Last Post: Bullet64
