Image Roll - new image viewer for phosh/gnome
(06-13-2021, 07:26 AM)Ralf Wrote: Hi Weclaw,
I am not familiar with Mobian, just started a bit. I could install it and it runs fine.
I would like to have an overview of pictures of an folder as a preview. And the option to delete pictures. And maybe to see the file-name of the opened picture.
If a picture is opened via fit screen and I zoom it to e. g. 20% it is not possible to see "fit screen" in menu which is the most important one.
Thank you for the work!
best regards
Ralf
Displaying of file names is something I will add in the next release, option to delete pictures will also be implemented, but most likely at a later release.
The problem with zoom is a bug which will have to be fixed by using libhandy or migration to GTK4.
RE: Image Roll - new image viewer for phosh/gnome - by weclaw - 06-13-2021, 03:22 PM
Photo Mobian with X11 without Wayland and Phosh. Manieck71 0 1,098 09-09-2023, 07:35 AM
Last Post: Manieck71
  How to disable lock screen in Phosh? lat 14 14,681 03-31-2023, 04:17 AM
Last Post: Eugo
  Fedora + Phosh for PinePhone njha 74 134,457 12-12-2022, 10:19 PM
Last Post: wcdeich4@hotmail.com
  Mepo - Minimalist and hackable OSM map viewer for mobile linux mil 22 15,266 10-31-2022, 07:29 AM
Last Post: mil
  Enable 'upcoming-events' on Mobian/Phosh Korac 3 2,351 09-14-2022, 01:19 AM
Last Post: dukla2000
  Advise: ENABLE animations before updating phosh! Otherwise freezes and crashes! dante404 5 3,425 08-18-2022, 02:03 PM
Last Post: dante404
  Phosh message notifications issue itstoughtofocus 2 2,782 08-15-2022, 06:39 AM
Last Post: nemsys
  Most Power Efficient OS Image jwinarske 0 867 07-05-2022, 07:05 PM
Last Post: jwinarske
Photo GNOME Display Orientation Unregistered Guest 0 786 05-20-2022, 06:09 AM
Last Post: Unregistered Guest
  Building an image with phosh liara 1 1,874 02-01-2022, 08:26 AM
Last Post: kqlnut
