I just got to find phone in my sd card won't read
(06-02-2021, 10:12 PM)nightranger73 Wrote: If you boot from EMMC (internal memory) and you want to use your SD as data storage you need to mount it from terminal.
There's no automount in phosh or plasma-mobile
Assuming you have only 1 partition on your SD, try this:
cd ~
mkdir ~/SDCard
sudo mount /dev/mmcblk1p1 ~/SDCard
if everything is fine you can edit /etc/fstab to permanently mount it at boot
its like the cd card isnt fitting right
RE: I just got to find phone in my sd card won't read - by Tyro - 06-05-2021, 01:22 PM
  My new phone stopped working. gunnygee 3 2,110 12-12-2024, 01:21 PM
  Pine Phone in Australaa and Telstra tracyanne 2 1,229 12-06-2024, 02:42 AM
Last Post: tracyanne
  Can't complete update of manjaro: wwan0 stays disabled; no phone/text gilford 3 1,328 12-05-2024, 06:42 AM
Last Post: gilford
  2G, 3G still is in phone. Piotr Bujakowski 5 2,789 09-19-2024, 03:49 AM
Last Post: jennybaso
  Looking for the "non-phone" OS wakyct 7 4,563 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 8,252 03-11-2024, 10:42 PM
Last Post: Emelia525
  install iso from sd card to emmc aular 2 2,022 03-11-2024, 10:24 PM
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 2,212 01-09-2024, 07:02 PM
Last Post: britelite
  Can the Pine Phone be serviced and updated remotely? profileyourcity 3 2,466 10-02-2023, 05:19 PM
  UBports on pine phone? robb777 16 9,891 09-01-2023, 04:26 AM
Last Post: gregb49
