Quectel EG25-G Modem Configuration - ofono - Manjaro Plasma
The modem always functions on the base of two services, the one is always eg25-manager which controls the power on/off of the device and the other one is either ofono or ModemManager, which can be controlled up to a point with `ofonoctl` and `mmcli` respectively.
Here we use ofono which is deployed by Manjaro Plasma Mobile, while other distributions like Manjaro Phosh use ModemManager.
Morover everything having to do with communications is controlled by the Telepathy framework in Plasma so here is a useful documentation book
https://telepathy.freedesktop.org/doc/book/index.html
AT Commands
For the moment we leave aside the AT commands except for the case we want to completely power off the modem with the following command
`echo at+qpwd=1 | sudo atinout - /dev/EG25.MODEM -`
`qpwd=1` means normal power down while `qpwd=0` means emergency power down, these commands start with "q" because they are Quectel specific and shouldn`t be working on other manufacturers
Flight Mode
First Method
The modem has several operating modes, here we are interested in 3
1) Normal
`echo at+cfun=1,0 | sudo atinout - /dev/EG25.MODEM -`
2) Minimum Functionality
`echo at+cfun=0,0 | sudo atinout - /dev/EG25.MODEM -`
when you return from this mode to "Normal" you should enter the pin again
`qdbus --system org.ofono /quectelqmi_0 org.ofono.SimManager.EnterPin pin your_pin`
3) Airplane Mode
`echo at+cfun=4,0 | sudo atinout - /dev/EG25.MODEM -`
Second Method
You can either disconnect the modem by stopping ofono and starting it again when needed or even cut the power completely like with the AT commands
-------------- Disconnect ----------------
`sudo systemctl stop ofono`
-------------- Reconnect --------------
`sudo systemctl start ofono`
`ofonoctl online`
-------------- Turn off ---------------
`sudo systemctl stop eg25-manager`
-------------- Turn on & Connect --------------
`sudo systemctl start eg25-manager`
`ofonoctl online`
Note that ofono affects the Bluetooth so don`t turn it off if you are using a Bluetooth connection at that moment. Ofono should be restarted so that the modem regains the `/quectelqmi_0` identity else it will be `/quectelqmi_(1,2,3....)` and the phone dialer won`t be able to make calls, you can then only trigger a call from the terminal as shown later.
Some basic operations can be performed with ofonoctl, type
`ofonoctl --help`
oFono and D-Bus - Working with qdbus
As every application/service ofono registers itself in DBus which can be manipulated by `qdbus`. If it is not installed open Discover and install Qt QDbusViewer.
Here we assume that the modem is not rejected by the network operator based on its IMEI so we should have Call and SMS functionality out-of-the-box for most users and we will try to configure the mobile data and the MMS.
If we command `qdbus --system` we will get a list of all the services registered in DBus, somewhere in the list we will see `org.ofono` so we issue `qdbus --system org.ofono` and we get the 2 lists for the two devices controlled by ofono, i.e. `/bluetooth` and `/quectelqmi_0`
the one thing that interests us is the contexts, you should see at least 1 entry `/quectelqmi_0/context1`
in fact we will need one for the internet and one for the MMS, so we should create one more context
`qdbus --system org.ofono /quectelqmi_0/context1`
will show us all the possible actions that can be performed on the given context, so we will configure it for mobile data
now we inspect the context with the `GetProperties` method which takes no arguments since the parenthesis is empty, so we issue
`qdbus --system org.ofono /quectelqmi_0/context1 org.ofono.ConnectionContext.GetProperties`
here we need to set up the `AccessPointName` and the `AuthenticationMethod` to `none`, the `Name` can be set to anything you like , `Type` should already be `internet` and the `Protocol` should be `ip`. The Access Point Name (APN) is provided by your operator so search the operator`s website, let`s assume it is `internet.apn.com`
`qdbus --system org.ofono /quectelqmi_0/context1 org.ofono.ConnectionContext.SetProperty Name Internet`
`qdbus --system org.ofono /quectelqmi_0/context1 org.ofono.ConnectionContext.SetProperty AccessPointName internet.apn.com`
`qdbus --system org.ofono /quectelqmi_0/context1 org.ofono.ConnectionContext.SetProperty AuthenticationMethod none`
now try to enable and disable the mobile data from drop down menu 2 times and the context should be activated giving you access to the internet, if not, reboot the phone and try again to enable and disable the mobile data 2 times.
If the context is enabled you should see a tick in the `Active` box by going to `Settings > Cellular Networks > Access Points` or else you issue again
and you will see `Active: true` plus some new entries like `DNS`, `IP address` etc with their respective values, the NetworkManager should automatically configure the `wwan0` interface which represents the Quectel modem.
Another way to inspect the connection is with `ofonoctl wan`, the table should be filled with all the appropriate values and not be empty.
--------------  MMS Configuration - Not Tested --------------
For the MMS you should create a new context of MMS type, and then you have to configure the `MessageCenter` and `MessageProxy` values according to your operator
`qdbus --system org.ofono /quectelqmi_0 org.ofono.ConnectionManager.AddContext mms`
`qdbus --system org.ofono /quectelqmi_0/context2 org.ofono.ConnectionManager.SetProperty MessageCenter operators_Message_Center`
`qdbus --system org.ofono /quectelqmi_0/context2 org.ofono.ConnectionManager.SetProperty MessageProxy operators_Message_Proxy`
you may need to set up other parametres too so follow your operator`s instructions
try again to reboot your phone and check that the context is activated
`qdbus --system org.ofono /quectelqmi_0 org.ofono.ConnectionManager.GetContexts`
`qdbus --system org.ofono /quectelqmi_0/context2 org.ofono.ConnectionContext.GetProperties`
Full Set of Quectel D-Bus commands
The full set of commands that can be sent to the modem by ofono are listed with the following command though here we have formatted the text to be readable, it naturally appears as a dense list.
`qdbus --system org.ofono /quectelqmi_0`
Some interesting command examples are shown
`qdbus --system org.ofono /quectelqmi_0 org.ofono.Modem.GetProperties`
`qdbus --system org.ofono /quectelqmi_0 org.ofono.NetworkMonitor.GetServingCellInformation`
`qdbus --system org.ofono /quectelqmi_0 org.ofono.RadioSettings.GetProperties`
-------------- Making a call --------------
`qdbus --system org.ofono /quecteqmi_0 org.ofono.VoiceCallManager.Dial call_number "" `
the quotation marks at the end stand for the second argument which is blank, after issuing the command the plasmaphonedialer should automatically pop up calling to the given number
Introspect
method QString org.freedesktop.DBus.Introspectable.Introspect()
Modem
signal void org.ofono.Modem.PropertyChanged(QString name, QDBusVariant value)
method QVariantMap org.ofono.Modem.GetProperties()
method void org.ofono.Modem.SetProperty(QString property, QDBusVariant value)
Voice Call Manager
signal void org.ofono.VoiceCallManager.BarringActive(QString type)
signal void org.ofono.VoiceCallManager.CallAdded(QDBusObjectPath path, QVariantMap properties)
signal void org.ofono.VoiceCallManager.CallRemoved(QDBusObjectPath path)
signal void org.ofono.VoiceCallManager.Forwarded(QString type)
signal void org.ofono.VoiceCallManager.PropertyChanged(QString name, QDBusVariant value)
method QList<QDBusObjectPath> org.ofono.VoiceCallManager.CreateMultiparty()
method QDBusObjectPath org.ofono.VoiceCallManager.Dial(QString number, QString hide_callerid)
method void org.ofono.VoiceCallManager.DialLast()
method void org.ofono.VoiceCallManager.DialMemory(uint memory_location)
method {D-Bus type "a(oa{sv})"} org.ofono.VoiceCallManager.GetCalls()
method QVariantMap org.ofono.VoiceCallManager.GetProperties()
method void org.ofono.VoiceCallManager.HangupAll()
method void org.ofono.VoiceCallManager.HangupMultiparty()
method void org.ofono.VoiceCallManager.HoldAndAnswer()
method QList<QDBusObjectPath> org.ofono.VoiceCallManager.PrivateChat(QDBusObjectPath call)
method void org.ofono.VoiceCallManager.ReleaseAndAnswer()
method void org.ofono.VoiceCallManager.ReleaseAndSwap()
method void org.ofono.VoiceCallManager.SendTones(QString SendTones)
method void org.ofono.VoiceCallManager.SwapCalls()
method void org.ofono.VoiceCallManager.Transfer()
Sim Manager
signal void org.ofono.SimManager.PropertyChanged(QString name, QDBusVariant value)
method void org.ofono.SimManager.ChangePin(QString type, QString oldpin, QString newpin)
method void org.ofono.SimManager.EnterPin(QString type, QString pin)
method QByteArray org.ofono.SimManager.GetIcon(uchar id)
method QVariantMap org.ofono.SimManager.GetProperties()
method void org.ofono.SimManager.LockPin(QString type, QString pin)
method void org.ofono.SimManager.ResetPin(QString type, QString puk, QString newpin)
method void org.ofono.SimManager.SetProperty(QString property, QDBusVariant value)
method void org.ofono.SimManager.UnlockPin(QString type, QString pin)
Allowed APNs
method QStringList org.ofono.AllowedAccessPoints.GetAllowedAccessPoints()
Message Waiting
signal void org.ofono.MessageWaiting.PropertyChanged(QString name, QDBusVariant value)
method QVariantMap org.ofono.MessageWaiting.GetProperties()
method void org.ofono.MessageWaiting.SetProperty(QString property, QDBusVariant value)
Supplementary Services
signal void org.ofono.SupplementaryServices.NotificationReceived(QString message)
signal void org.ofono.SupplementaryServices.PropertyChanged(QString name, QDBusVariant value)
signal void org.ofono.SupplementaryServices.RequestReceived(QString message)
method void org.ofono.SupplementaryServices.Cancel()
method QVariantMap org.ofono.SupplementaryServices.GetProperties()
method QString org.ofono.SupplementaryServices.Initiate(QString command, QDBusVariant& value)
method QString org.ofono.SupplementaryServices.Respond(QString reply)
Network Monitor
method {D-Bus type "a(a{sv})"} org.ofono.NetworkMonitor.GetNeighbouringCellInformation()
method QVariantMap org.ofono.NetworkMonitor.GetServingCellInformation()
method void org.ofono.NetworkMonitor.RegisterAgent(QDBusObjectPath path, uint period)
method void org.ofono.NetworkMonitor.UnregisterAgent(QDBusObjectPath agent)
Connection Manager
signal void org.ofono.ConnectionManager.ContextAdded(QDBusObjectPath path, QVariantMap properties)
signal void org.ofono.ConnectionManager.ContextRemoved(QDBusObjectPath path)
signal void org.ofono.ConnectionManager.PropertyChanged(QString name, QDBusVariant value)
method QDBusObjectPath org.ofono.ConnectionManager.AddContext(QString type)
method void org.ofono.ConnectionManager.DeactivateAll()
method {D-Bus type "a(oa{sv})"} org.ofono.ConnectionManager.GetContexts()
method QVariantMap org.ofono.ConnectionManager.GetProperties()
method void org.ofono.ConnectionManager.RemoveContext(QDBusObjectPath path)
method void org.ofono.ConnectionManager.ResetContexts()
method void org.ofono.ConnectionManager.SetProperty(QString property, QDBusVariant value)
Radio Settings
signal void org.ofono.RadioSettings.PropertyChanged(QString name, QDBusVariant value)
method QVariantMap org.ofono.RadioSettings.GetProperties()
method void org.ofono.RadioSettings.SetProperty(QString property, QDBusVariant value)
Network Registration
signal void org.ofono.NetworkRegistration.PropertyChanged(QString name, QDBusVariant value)
method {D-Bus type "a(oa{sv})"} org.ofono.NetworkRegistration.GetOperators()
method QVariantMap org.ofono.NetworkRegistration.GetProperties()
method void org.ofono.NetworkRegistration.Register()
method {D-Bus type "a(oa{sv})"} org.ofono.NetworkRegistration.Scan()
Message Manager
signal void org.ofono.MessageManager.ImmediateMessage(QString message, QVariantMap info)
signal void org.ofono.MessageManager.IncomingMessage(QString message, QVariantMap info)
signal void org.ofono.MessageManager.MessageAdded(QDBusObjectPath path, QVariantMap properties)
signal void org.ofono.MessageManager.MessageRemoved(QDBusObjectPath path)
signal void org.ofono.MessageManager.PropertyChanged(QString name, QDBusVariant value)
method {D-Bus type "a(oa{sv})"} org.ofono.MessageManager.GetMessages()
method QVariantMap org.ofono.MessageManager.GetProperties()
method QDBusObjectPath org.ofono.MessageManager.SendMessage(QString to, QString text)
method void org.ofono.MessageManager.SetProperty(QString property, QDBusVariant value)
Push Notification
method void org.ofono.PushNotification.RegisterAgent(QDBusObjectPath path)
method void org.ofono.PushNotification.UnregisterAgent(QDBusObjectPath path)
Smart Messaging
method void org.ofono.SmartMessaging.RegisterAgent(QDBusObjectPath path)
method QDBusObjectPath org.ofono.SmartMessaging.SendAppointment(QString to, QByteArray appointment)
method QDBusObjectPath org.ofono.SmartMessaging.SendBusinessCard(QString to, QByteArray card)
method void org.ofono.SmartMessaging.UnregisterAgent(QDBusObjectPath path)
Long Term Evolution (LTE)
signal void org.ofono.LongTermEvolution.PropertyChanged(QString name, QDBusVariant value)
method QVariantMap org.ofono.LongTermEvolution.GetProperties()
method void org.ofono.LongTermEvolution.SetProperty(QString property, QDBusVariant value)
Quectel EG25-G Modem Configuration - ofono - Manjaro Plasma - by mouffa - 05-27-2021, 09:24 AM
  Supported Carrier and Modem Bands NachoMomma 4 1,645 03-23-2024, 02:00 PM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 581 02-17-2024, 04:15 PM
Last Post: vortex
Bug PinePhone modem keeps "disappearing" Kevin Kofler 14 5,817 03-22-2023, 05:28 PM
  PinePhone keyboard layout with manjaro plasma daemonbsd 0 974 03-02-2023, 05:01 AM
Last Post: daemonbsd
  modem not working michelinux 0 942 02-16-2023, 04:56 AM
Last Post: michelinux
  modem not detected al_x 3 4,298 02-15-2023, 11:17 AM
Last Post: fxc
  firmware udate Quectel EG25-G modem alwi 7 5,494 07-06-2022, 01:43 PM
Last Post: user641
  Need command to tell what modem firmware I am on. purpletiger 4 2,923 07-06-2022, 12:35 PM
  The modem does not recognize Korean SIM cards (what?) bdicewk 9 4,224 06-13-2022, 04:12 AM
Last Post: zetabeta
  Modem Hardware bad? Not ready for 5g?? linux76 8 4,836 05-31-2022, 06:41 PM
Last Post: SwordfishII
