Buiding apps for pinephone
(05-29-2021, 01:51 AM)Trbl Wrote: https://imgur.com/a/n44dZsL
Building apps on the PinePhone is a blessing compared to iOS/Android/WP.
You can code on your linux device, rsync the binary over to the pinephone, use SSH with X Forwarding to run the application on the phone but get the actual Window back to your workstation. I can do that without even having to connect my pinephone to my laptop with a cable, i can just rsync and x-forward over wifi, 4g or even fucking bluetooth if i had to.
It feels exactly like writing desktop applications. There's no emulators or special SDKs, everything just works as you'd expect.
When you say, "rsync the binary over to the pinephone" that means you are compiling it somewhere else and if so then where and how?
Or are you compiling your code on the pinephone64?
I compiled hello world on my Raspberry Pi4 but the binary didnt work on the Pinephone64 so if you can include that in your explanation that would be great too.
For additional context, I code in self-defense to get stuff done repeatedly sort of correct the second time around in a DevOps-ish way - so there is that.
I do have VScode install on my Pi and thinking if can ssh to the Pine64 to also code on it.
Thanks.
Buiding apps for pinephone - by katesfb - 05-25-2021, 10:08 PM
RE: Buiding apps for pinephone - by evilbunny - 05-26-2021, 04:34 AM
RE: Buiding apps for pinephone - by katesfb - 05-26-2021, 11:21 PM
RE: Buiding apps for pinephone - by evilbunny - 05-29-2021, 02:39 AM
RE: Buiding apps for pinephone - by vortex - 05-27-2021, 03:17 PM
RE: Buiding apps for pinephone - by Trbl - 05-29-2021, 01:51 AM
RE: Buiding apps for pinephone - by nbh - 04-13-2022, 02:55 PM
RE: Buiding apps for pinephone - by katesfb - 06-10-2021, 10:52 PM
RE: Buiding apps for pinephone - by Peter Gamma - 03-29-2022, 05:25 AM
RE: Buiding apps for pinephone - by presire - 06-03-2022, 07:29 AM
  PinePhone - boot from microSD laserpyramid 7 639 04-25-2024, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 369 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 249 04-02-2024, 11:50 AM
  Writing apps/programs for pine phone katesfb 7 5,104 03-11-2024, 10:42 PM
Last Post: Emelia525
  Are you using the Pinephone as your daily driver? jro 157 109,751 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,858 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 626 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,412 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 512 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,742 12-22-2023, 03:44 PM
