dependency problem
Hello All,
I just got the new Pinebook Pro and probably somehow screwed the dependencies on first software install attempt (vi, mutt, xterm and a couple of apps from the Recommendation section) It failed and any subsequent attempt to install basically anything reports an error Conflicting dependencies: opensmtpd and msmtp-mta are conflicting  (translation from my native language mine). Installation by pacman seems to work (tested on only few packages though). Is there any way to fix it? I have no prior Manjaro experience and for some time the ability to use high-level package manager would be... well, handy.
Many Thanks,
cerno
dependency problem - by cerno - 05-07-2021, 07:36 AM
RE: dependency problem - by tophneal - 05-07-2021, 07:54 AM
RE: dependency problem - by cerno - 05-07-2021, 08:09 AM
RE: dependency problem - by tophneal - 05-07-2021, 08:13 AM
RE: dependency problem - by cerno - 05-07-2021, 08:18 AM
  New RockPro64 Power Up Problem enorbet2 7 8,214 10-28-2023, 12:08 PM
Last Post: dkebler
  First Boot HDMI/USB problem reefer 1 5,932 11-18-2018, 10:32 PM
  ethernet lan speed problem android fulltone 0 3,136 04-23-2018, 01:47 AM
Last Post: fulltone
  Boot problem AdamK 1 5,720 12-15-2016, 06:51 PM
  remix os Phoenix CARD and Win32 Problem pilgrimage 4 8,781 08-17-2016, 02:30 AM
Last Post: pfeerick
  Boot Up Problem - Red LED goes Out hay.barry 6 14,152 07-28-2016, 02:48 PM
Last Post: Ghost
Bug ETA for solution for DMA problem for Arch Linux image & A64+ 2 GB boards? faddah 16 28,185 04-19-2016, 09:09 PM
Last Post: patrickhwood
  Problem with setting up SD Card Win10 montyflange 8 13,625 04-05-2016, 03:15 PM
Last Post: jbritt
