Is HDCP absolutely needed?
(06-21-2016, 02:36 AM)xalius Wrote: Android images probably have it enabled so that Netflix and co. work and so likely non HDCP displays or using an adapter for DVI/VGA will have issues?
My odroid c2 has HDCP disabled and Netflix works on android.
Without Widevine DRM, Netflix works only with low resolution (no HD), even when HDCP is turned on.
On another android box (without HDCP), Netflix works too (only SD resolution).
For HD resolution you need both Widevine DRM and HDCP. Without Widevine DRM, HDCP is useless.
Gesendet von meinem SM-N910F mit Tapatalk
Is HDCP absolutely needed? - by diwou - 06-14-2016, 05:57 AM
RE: Is HDCP absolutely needed? - by g_t_j - 06-14-2016, 06:06 AM
RE: Is HDCP absolutely needed? - by tllim - 06-14-2016, 11:14 AM
RE: Is HDCP absolutely needed? - by xalius - 06-19-2016, 02:46 PM
RE: Is HDCP absolutely needed? - by ragwafire - 06-20-2016, 11:17 PM
RE: Is HDCP absolutely needed? - by xalius - 06-21-2016, 02:36 AM
RE: Is HDCP absolutely needed? - by diwou - 06-21-2016, 05:28 PM
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 66 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  NOOB: Z Wave discovery in OpenHAB help needed JamesWatt 2 4,457 10-22-2016, 05:28 AM
Last Post: JamesWatt
  Pine64 Boot help needed jousley 4 6,156 06-15-2016, 10:35 AM
Last Post: jl_678
  Help needed Install Android using Mac OS X gubaguba 4 7,030 03-23-2016, 05:51 AM
Last Post: Andrew2
