GTK Rust mobile Linux client for Signal
Do not clutter this thread with criticisms of Signal. Take that discussion elsewhere please.
I've been following the issue of getting Signal working on Linux smartphones for a while and I've come to the conclusion that it is probably best if we start a new client application. The Signal developers are uninterested in making their clients work for our use case. The Signal "Desktop" (Electron) client does not and will not support registering an account, is not designed for small screens, and does not build on ARM. The latter two issues may be fixed upstream (eventually), but they've specifically said they do not want to make the Electron client have feature parity with the Android and iOS clients. I doubt using the Android client in Anbox would be a good long term solution for battery or RAM usage.
So I think we need a native Linux client. I do not think Axolotl is a viable long term solution because it uses its own implementation of the Signal network protocol (written in Go). Reimplementing the cryptography and network protocol is a ton of work and will continue to be a ton of work as upstream adds more features. Axolotl has only just started reimplementing the new Signal groups protocol which was introduced Also, the security of a reimplementation is dubious.
Fortunately, the Signal developers are now using a new Rust library with bindings to C, Java, Swift, and TypeScript for their own clients. Currently this is undocumented and does not yet implement all the logic necessary to write a complete client. However, upstream has advised that using this new library would be the best option for starting a new client. Considering there is a C FFI (which I presume they implemented to implement the S, it may be possible to add Signal support to libpurple which is used by Chatty. However, I am doubtful that would work out well. libpurple was made in a different era when messaging didn't include audio and video calls, emoji reactions, or disappearing messages. Trying to cram those into the libpurple API may be more trouble than it is worth. I would also be concerned about starting a new project using such an old code base which I am guessing has quite a bit of legacy cruft.
So, I think the best way forward would be a new client using the Rust bindings for GTK so the upstream libsignal-client, zkgroup, and ringrtc Rust libraries can be used directly. I don't have much experience developing with Rust or GTK and I barely know anything about cryptography, plus I already maintain another very complex application, so I couldn't lead development of this but I'd be happy to test and contribute code where I can. I am starting this thread to try to organize people who are interested in working on this.
I propose this roadmap for implementing features:
1. Device registration
2. Sending and receiving text messages
3. Import contacts
4. Use the WebSocket API for notifications like the Android client does on Android with neither Google Play nor microG
5. File attachments
6. Voice calls
7. Video calls
8. Device linking. If we could get this application to link to itself, that could be an awesome way to have the primary installation on a PinePhone and use the same application on a Linux laptop.
9. Figure out a way to do notifications in a more battery friendly way. This will require cooperation with the Signal Foundation and we may need to write the changes for the server software ourselves. Maybe OpenPush? Or perhaps get Firebase push notifications working on Linux without Android?
10. SMS support
11. MMS support
I think the GUI design could largely copy the Android client.
GTK Rust mobile Linux client for Signal - by Be. - 04-10-2021, 10:15 PM
  Using Signal on PinePhone in mid-2023? dante404 47 14,079 05-03-2024, 02:19 AM
Last Post: dragonhospital
  Alternatives to Signal or simple signal setup methods? JamesBond009 3 737 04-25-2024, 02:22 PM
Last Post: TRS-80
  Sms apps and signal messenger boggle 8 7,542 02-16-2024, 06:03 AM
Last Post: zetabeta
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 1,058 11-04-2023, 07:23 PM
  Abiword as a office mobile word processor for the Pinephone? Peter Gamma 11 2,466 10-24-2023, 08:57 AM
Last Post: Peter Gamma
  Proximity lock on Plasma Mobile alpineduck 0 1,053 08-14-2023, 05:51 PM
Last Post: alpineduck
  Introducing Harborz: Lightweight Rust Music Player for Pinephone ravenblackdusk 1 1,226 08-07-2023, 12:05 AM
Last Post: ravenblackdusk
Information Quick&dirty VPN quick setting button for Plasma Mobile Kevin Kofler 0 1,064 04-06-2023, 02:40 PM
  Arch Linux on PinePhone Rocky-IV 4 9,860 12-21-2022, 04:35 AM
Last Post: gregb49
  Mepo - Minimalist and hackable OSM map viewer for mobile linux mil 22 14,932 10-31-2022, 07:29 AM
Last Post: mil
