Battery gauge issue (mainline kernel)
(05-22-2021, 03:58 AM)lfourquaux Wrote: Answering my own post: this was caused by missing drivers in the Debian kernel: enabling CONFIG_TYPEC_FUSB302 (requires CONFIG_TYPEC and CONFIG_TYPEC_TCPM) and CONFIG_SND_SOC_ES8316 makes the type-c port, battery gauge and audio work.
This is currently fixed in Debian sid (from version 5.10.38-1 of linux-image-amd64).
I believe you meant `linux-image-arm64`. What's your experience with it so far? I've seen some instability around WiFi - device likes to disappear out of the blue, haven't noticed any pattern yet. With xmixahx's 5.8.x I had it disappear only occasionally after deep sleep, but with 5.10.0-7 of Debian it can sometimes disappear in the middle of my typing up a message in IM.
(05-22-2021, 03:58 AM)lfourquaux Wrote: One remaining oddness is that the usb-c port does not always work in all orientations: reversing the usb connector can make a usb device work.  Does anyone understand why this is happening?
AFAIK Type-C is not perfectly reversible, and that was brought up before. Somebody on these forums even referred to the USB-C spec not guaranteeing 100% reversible connection. Which seems to me to defeat the purpose, but oh well. I haven't spent enough time reading the spec to tell whether it is an issue with the hardware spec or if it is a software (driver) issue.
This message was created with 100% recycled electrons
RE: Battery gauge issue (mainline kernel) - by moonwalkers - 05-22-2021, 09:53 AM
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,448 09-07-2023, 09:38 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 775 08-18-2023, 02:06 AM
Last Post: juliamenendez
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 977 08-18-2023, 01:58 AM
  kernel module that supports usb-c hdmi alexandre 16 14,609 05-14-2023, 09:58 PM
Last Post: rathofkhan3
  Manjaro update: nerd-font-terminus dependency issue Vinay 3 1,341 05-10-2023, 04:51 AM
Last Post: Vinay
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,280 12-09-2022, 12:43 PM
Last Post: as365n4
  Manjaro update: wxgtk dependency issue Vinay 5 2,565 09-09-2022, 12:03 PM
Last Post: Vinay
  bootloader menu to pick a kernel - what is the current situation in in early 2022? maxtothemax 4 3,155 02-05-2022, 03:04 PM
Last Post: maxtothemax
  Kernel panics solostian 17 14,212 01-26-2022, 08:08 AM
Last Post: TRS-80
  Kernel 5.17 will improve VP9 support? jiyong 1 2,126 01-16-2022, 08:26 PM
Last Post: xmixahlx
