ALERT: The hard "protective" case sucks!
(06-27-2021, 10:47 PM)adjf873_n-s Wrote: I haven't tried out the soft and hard cases but, any cursory understanding of physics would inform one to purchase a soft case over a hard case. The damage done to a phone (or anything) on impact is going to be due to the power profile of the impact and, basically, power=energy/time. A soft case is going to increase the amount of time in this equation, hence lowering the power profile of the impact. There is other physics at play here, but that is the main issue with any concussive impact. So, take it from someone with a physics degree, tend towards a soft case unless you have irrefutable proof that a hard case will provide more protection.
Yes this,
Another physics problem though is landing on a narrow point where the total force is expressed onto a very small inflexible surface area.
The ideal case would have an outer 'armor' of a hard material to spread out the force, probably also a stiff closing cover over the fragile and nonflexible glass, to protect against a point impact event spreading the force onto adjf873_n-s's described soft inner armor to extend the ∆v over time reducing the peak Gs experienced.
I have an Otter brand hard/soft case like this for my Nokia N900 and a Trident brand hard/soft case for my Asus/Google Nexus-7 2013 which have served me well over the years with damage only occurring to the tablet when out of the armor The N900 is so small there was never an event where the fall had enough mechanical advantage to damage the uncased metal bezel screen or slider rails.  All of my N900s died from either PCB flex de-balling the modem IC or USB port breaking solder points form the PCB(new lead free solder and weak solder pad only anchored microUSB design) never impact, maybe one or two from static discharge into the USB.
RE: ALERT: The hard "protective" case sucks! - by biketool - 06-28-2021, 04:49 AM
  Case for Pinephone totilele 13 7,678 04-11-2024, 11:48 AM
Last Post: gramonyl
  Slip/Zippered Case for PP/KB? jakfish 0 314 03-03-2024, 04:55 PM
Last Post: jakfish
  keyboard case charging but not typing new2pinephone 18 6,046 02-19-2024, 07:30 AM
Last Post: theResonant
  Getting all keys working on pine phone keyboard-case undata 5 2,569 10-08-2023, 12:19 PM
Last Post: mburns
  PinePhone Wallet Case Shane 5 5,117 09-17-2023, 12:52 PM
Last Post: J T
  pinephone keyboard case how to use the = f8 - etc tuxcall 3 1,848 05-02-2023, 05:18 PM
Last Post: undata
  Using Keyboard Case with Mobian (complete instructions) Megamemnon 4 5,084 03-22-2023, 01:47 PM
Last Post: vgnmnky
  Otterbox case for PinePhone car46999 5 3,287 11-18-2022, 09:08 PM
Last Post: car46999
  A Pinephone case that'll actually prevent the screen from cracking mil 24 16,975 11-18-2022, 02:18 PM
Last Post: mil
  Pinephone (Pro) Keyboard Case for sale manubert 0 970 09-17-2022, 11:51 AM
Last Post: manubert
