Forget Chromium, Vivaldi runs flawlessly!
(02-27-2021, 08:47 AM)3x5co Wrote: It is based on Chromium, but I think Vivaldi does a lot of things better than Chromium. The interface is more customizable, so I can fit it to my mobian screen more easily. The original reason I switched is that you can disable all suggestions in the omnibar, which you can't do in Chromium.
I'm not worried about it leaking my user agent string. I've thought about running it through a VPN to protect my privacy and anonymity, if that's what you're worried about. I would imagine the Mobian footprint is pretty unique no matter what.
Actually with Chromium (or Chrome for that matter) if you set a null search engine as default I don't think there will be any suggestions in the omnibar. (I have not seen any in my desktop Chromium other than from browser history.) Of course you won't be able to search in the omnibar either, you have to go back to duckduckgo.com or whatever search engine you use.
I might give Vivaldi a spin nonetheless to see how it compares.
RE: Forget Chromium, Vivaldi runs flawlessly! - by Zebulon Walton - 02-27-2021, 10:16 AM
  Web Skype, Vivaldi and built in cameras grump_fiddle_reinstall 7 4,216 01-09-2022, 01:53 AM
  Can't type @ from keyboard in chromium flatpak motox6 1 2,047 06-17-2021, 07:18 PM
Last Post: pjsf
  vivaldi only uses half the screen for website display motox6 0 1,267 05-22-2021, 03:49 PM
Last Post: motox6
  Installing and tweaking Chromium on Mobian and Arch C0ffeeFreak 19 19,478 03-11-2021, 09:24 AM
Last Post: C0ffeeFreak
  Installing chromium browser? Zebulon Walton 12 13,739 02-09-2021, 12:33 PM
  Chromium doesn't seem to recognize that I'm on a mobile device 3x5co 2 2,842 02-05-2021, 11:13 PM
Last Post: 3x5co
