Strange SD Card Problems
(02-18-2021, 11:34 AM)anhilde Wrote: I finally managed to boot from a 32GB card. How did I do it? First I wrote the image to a new card. It did not boot... Then I tried again, this time pressing on the SD slot from the outside. I will check with my calipers later if that old 16GB card is actuall slightly thicker than the new ones...
That does sound a bit odd. But sdcards are finnicky ime.
Try overwriting it with random data instead of /dev/zero.
Use:
sudo dd if=/dev/urandom of=/dev/mmcblk0 bs=8M status=progress
After doing the above random overwrite, flash your image again. If the card is still alive it should work (not the same longevity as other storage). I had an issue where overwriting with 0's booted the previous OS, or wouldn't boot. Since using /dev/urandom I have had no problems, and for one reason or another, seems to fix most sdcard issues others have had.
Hope this helps. Smile
- RTP
"In the beginner's mind there are many possibilities, in the expert's mind there are few." -Shunryu Suzuki
[ Pinephone Original | Pinetab v1 / v2 Enjoyer ]
Linux Device Privacy / Security Playlist
Strange SD Card Problems - by anhilde - 02-18-2021, 06:42 AM
RE: Strange SD Card Problems - by anhilde - 02-18-2021, 11:34 AM
RE: Strange SD Card Problems - by RTP - 02-18-2021, 12:02 PM
RE: Strange SD Card Problems - by dsimic - 02-19-2021, 10:12 AM
RE: Strange SD Card Problems - by anhilde - 02-21-2021, 01:48 AM
RE: Strange SD Card Problems - by anhilde - 02-18-2021, 02:38 PM
RE: Strange SD Card Problems - by TRS-80 - 02-19-2021, 01:41 PM
RE: Strange SD Card Problems - by Zebulon Walton - 02-21-2021, 07:52 AM
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 24,415 01-29-2023, 12:20 PM
Last Post: skandigraun
  Pinephone won't boot from SD card arkadione 3 3,512 05-25-2022, 03:26 PM
Last Post: sfb
  Largest supported micro SD card? zooidic 2 2,062 01-08-2022, 06:01 AM
Last Post: zooidic
  Red LED when trying to boot from SD card. Need advice. サーバント 5 4,315 10-20-2021, 09:40 AM
  camera firmware problems kqlnut 25 22,029 09-02-2021, 07:49 PM
  Fragile SIM card connector hakkou 1 1,850 08-25-2021, 07:44 AM
Last Post: wibble
  camera + megaixel and strange behavior streak 0 1,711 06-02-2021, 06:45 AM
Last Post: streak
  Sd card slot death? Hurrikan 7 6,643 05-17-2021, 03:55 PM
Last Post: jrballesteros05
  WARNING to future users ~ Order yourself a SIM Card Extender Bonesdog 3 4,039 05-03-2021, 10:06 AM
Last Post: Bonesdog
  Fastest SD card happybot-4678 9 8,703 02-20-2021, 01:08 AM
Last Post: dsimic
