A64 TDP / max CPU temperature
(02-01-2021, 03:35 AM)grobbs Wrote:
(02-01-2021, 02:25 AM)barray Wrote: As far as I know, it should just thermal throttle.
Thanks. That should prevent the CPU from getting to hot but I'm curious where the threshold is. 70°C? 80°C? 90°C?
While running a CPU-intensive app, the temperature kept going up. Knowing the threshold would also help me see how effective the heatsink is.
In theory you could just keep increasing the temperature until you see the clock speed go down.
In general, try to keep it below 80 degrees, 70 degrees for prolonged use.
A small thermal mass (heat sink) is only really effective for short bursts of performance. If you want prolonged cooling you'll need active cooling, like a fan.
A64 TDP / max CPU temperature - by grobbs - 01-31-2021, 10:53 PM
RE: A64 TDP / max CPU temperature - by barray - 02-01-2021, 02:25 AM
RE: A64 TDP / max CPU temperature - by grobbs - 02-01-2021, 03:35 AM
RE: A64 TDP / max CPU temperature - by barray - 02-02-2021, 04:35 AM
  Is there a temperature sensor on Pine? Informatica 12 13,514 06-13-2016, 04:01 PM
Last Post: Ghost
