I can't create the microsd
It is confusing because there are different tools depending on the end goal.  I happen to use Windows and so here is a summary of the Windows tools.
Win32DiskImager - This is a rock solid program that is used to burn .img files to SD Cards.  You will use this to burn a Linux image to a card.  (Debian, Arch, Ubuntu, etc...)
PhoenixCard - This is a special tool to burn Android variants.  (Remix, Android, etc....)  I have not personally used this, but the forum is full of stories about how it can be finicky.  Regardless, you must use this tool if you want to create an Android image to use on your Pine.
I can't create the microsd - by Arkhanjel - 06-07-2016, 10:31 AM
RE: I can't create the microsd - by Luke - 06-07-2016, 10:40 AM
RE: I can't create the microsd - by jl_678 - 06-08-2016, 10:24 AM
RE: I can't create the microsd - by Ghost - 06-08-2016, 12:10 PM
  MicroSD, Which one should I buy? ronaldolcc 1 3,447 03-20-2017, 04:46 PM
Last Post: Luke
  Samsung EVO+ microSD simplexdan 7 7,916 03-02-2017, 03:31 AM
Last Post: pfeerick
