BSD host of issues on reboot from fresh install
~#: pkg install update     pkg update
~#: pkg install upgrade   pkg upgrade
~#: pkg install samba     pkg samba* (whatever version number came up in search)
and so on, had mixed results but do not remember which outputs were related to which commands.
Quote:Have you tried compiling ports on the rockpro64?
Not until your tutorial. I had to first update the machine time (~#: ntpd -g -u) then fetch and install the ports tree which took about 20mins where I am in the United States.
Quote:Be interested to know how long it takes to compile ports directly on the RK3399
If I understand the output from the
portmaster
command from /usr/ports/net/samba413, with
setenv batch=yes
then it took about 1.5 hours to run from the portmaster command until the terminal output reached docbook-sgml installed and began working on iso8879. Or 1.5 hours to compile and install 12 ports that are dependencies of samba. Or 12/151 ports, including samba from the previously linked pastebin. I hope that gives you an idea of speed.
I will likely see samba through on the RockPro64, 2GiB ram, w/32GB eMMC module but try the tutorial on cross compiling on my AMD Ryzen 7 3700X machine, hosting Debian Buster (Linux). I also have a RockPro64 with 4GiB of memory, wonder if that makes a difference.
It is worth noting that according to TOP, the CPUs are fluctuating from 12-99% load, higher with the cc command and between 12-29% with python3 showing. It appears to be cycling between CPU0, 1, 2, 3 for the heavy work.
Thank you for taking the time to write your tutorial, it gave me a solid place to start and answered my questions on how dependencies are handled!
Quartz64, RockPro64, PinePhone Mobian, PineBook Pro, PineTime, and all the trimmings that make FOSS fun.
RE: BSD host of issues on reboot from fresh install - by MNtinkerer - 02-26-2021, 03:31 PM
  OpenBSD install on eMMC without serial dcnetfan 1 278 04-12-2024, 02:06 AM
