Pinecil Broken?
The picture that didn't upload correctly
[Image: thumbnail?authuser=0&sz=w640&id=1S2-MfsJ...FBLiM7zQc5]
So I remove the FUSB302MPX with hot air station, before that I removed every solder I can with solder wick.
[Image: thumbnail?authuser=0&sz=w640&id=15Rt-rwB...fPkmOwRBZt]
I think it was glued to the pcb so it was difficult to remove, I had to melt it basically. It turn ok after cleaning
After that no more "shortcut" between 3v3 and gnd.
I salvage the 3v3 regulator from the breakout board and solder it on the pinecil.
Now It work like the other, same current 10-20 mA when idle, same voltage on screen.
I can plug usb, but I will use it with barrel jack for the moment.
I will try to solder back a new fusb and other regulator if I can find one.
Still I do not know what happened, if 3v3 failed it should have fried the microcontroller and the bma223 but both are working.
best bet is a bad FUSB from beginning.
Pinecil Broken? - by skaaq - 12-29-2020, 01:11 PM
RE: Pinecil Broken? - by VaZso - 12-29-2020, 03:53 PM
RE: Pinecil Broken? - by skaaq - 12-31-2020, 03:34 AM
RE: Pinecil Broken? - by VaZso - 01-02-2021, 04:43 AM
RE: Pinecil Broken? - by skaaq - 01-25-2021, 11:28 AM
Lightbulb Pinecil -> Pinegun? Avamander 18 20,279 10-13-2023, 02:25 PM
Last Post: denystify
Question How many SPI ports/buses are broken out/available on SOQUARTZ? gogerriko 5 2,050 04-05-2023, 10:34 AM
Last Post: gogerriko
Exclamation What is this - Pinecil V3? andrea6 2 6,818 12-19-2022, 08:11 PM
  on pinepower, pinecil stopped working.. sanderboer 1 1,169 09-23-2022, 03:47 AM
  Just got my Pinecil donwynne 1 1,634 04-22-2022, 07:01 AM
Last Post: bbeeast
  Broken forum? arno_nuehm 16 9,262 03-12-2022, 03:00 AM
Last Post: arno_nuehm
  Pine64 Zoho support site broken anomaly 2 3,341 02-08-2021, 09:03 PM
Last Post: anomaly
  Pinecil stuck in shipping? mbreese 3 4,864 01-07-2021, 07:46 AM
Last Post: moxx
  Pinecil - Tip Disconnected molzy 2 4,649 01-03-2021, 07:21 AM
Last Post: molzy
  Pinecil arrived VaZso 0 2,393 12-28-2020, 10:36 AM
Last Post: VaZso
