Unable to boot off SD card
(12-28-2020, 10:56 PM)Alho Wrote: There are no issues booting from SD on PineTab.
If you have verified that partitions and files are normally visible on the cards,
the only thing that comes to mind is, that you might have flashed a pinePHONE image,
instead of a pineTAB image. A pinephone image might "work"; but will not turn the screen
on, so it will look like nothing happens.
I'll double check when I get home.
Would the pinephone image also not light up the keyboard if I attempt to reboot with that connected?
BTW, I tried to get to Manjaro from the wiki and it goes to a file not found on NextCloud
Unable to boot off SD card - by gdsmit1 - 12-28-2020, 07:21 PM
RE: Unable to boot off SD card - by Alho - 12-28-2020, 10:56 PM
RE: Unable to boot off SD card - by gdsmit1 - 12-29-2020, 11:58 AM
RE: Unable to boot off SD card - by gdsmit1 - 12-29-2020, 06:09 PM
RE: Unable to boot off SD card - by tophneal - 12-30-2020, 02:51 PM
RE: Unable to boot off SD card - by gdsmit1 - 12-30-2020, 03:24 PM
  Booting from SD card on Pinetab2 samochimaaron 10 3,131 08-23-2023, 09:38 AM
Last Post: diederik
  failure to boot ajhiii070 0 756 07-07-2023, 01:19 PM
Last Post: ajhiii070
  Pinetab2: (multi)boot normal image on eMMC and some OS on SD- card Bart 3 1,996 06-10-2023, 03:24 PM
  SD card issues. pjsf 5 6,328 09-11-2020, 12:51 PM
Last Post: bartgrefte
