kernel module that supports usb-c hdmi
@alexandre As long as your hardware has worked once with your Pinebook Pro, then it's the right type. Sounds like it uses an internal convertor from DisplayPort to HDMI.
I can't really help you with the software aspect...
The USB C standard is one of the most bizarre and complicated things in existence. It & the connector tries to be everything to everyone, even when their are competing / conflicting standards. Like the alternate mode video options. First released was DisplayPort, so that is what many USB C alternate video mode devices use. Later came the USB C alternate mode HDMI video, which is NOT compatible with our Pinebook Pros.
As I said, it's complicated.
Arwen Evenstar
Princess of Rivendale
RE: kernel module that supports usb-c hdmi - by Arwen - 12-21-2020, 01:17 PM
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,566 09-07-2023, 09:38 PM
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,294 12-09-2022, 12:43 PM
Last Post: as365n4
  bootloader menu to pick a kernel - what is the current situation in in early 2022? maxtothemax 4 3,165 02-05-2022, 03:04 PM
Last Post: maxtothemax
  Kernel panics solostian 17 14,306 01-26-2022, 08:08 AM
Last Post: TRS-80
  Kernel 5.17 will improve VP9 support? jiyong 1 2,141 01-16-2022, 08:26 PM
Last Post: xmixahlx
  Solution for issue with 'panfrost' module not initializing due to missing dependency cobratbq 0 1,593 12-02-2021, 05:26 PM
Last Post: cobratbq
  red/green power led not working with kernel 5.14 alchemist 4 3,810 11-04-2021, 04:09 AM
Last Post: alchemist
  Sound stuttering on Manjaro gnome after latest kernel upgrade? pjsf 0 1,805 07-13-2021, 10:37 PM
Last Post: pjsf
  Kernel panic on boot with danielt's Debian installer hjalfi 11 11,274 07-09-2021, 08:52 AM
Last Post: moonwalkers
  Kernel crash on Manjaro ARM mfashby 0 1,605 07-06-2021, 03:17 PM
Last Post: mfashby
