very low buzz noise
(12-12-2020, 04:21 AM)LMM Wrote: The Rockpro64 boards emit a buzz noise (audible only at some centimeters), this is probably due to the converters. However. there is no noise at all on the rock64. Then, I am wondering if it is not due to 12V instead of the 5V for rock64. Is there a reason for this choice ? reduce current ?
Powering with GPIO 5V does not reduce the noise
The buzz noise may comes from inductor vibration. You can put some glue or wax on the inductors and the noise may goes away.
very low buzz noise - by LMM - 12-12-2020, 04:21 AM
RE: very low buzz noise - by tllim - 12-15-2020, 12:23 AM
RE: very low buzz noise - by LMM - 12-15-2020, 05:04 PM
RE: very low buzz noise - by tllim - 12-15-2020, 09:51 PM
RE: very low buzz noise - by LMM - 12-18-2020, 03:04 AM
  NAS setup: weird noise and reboot with 2 3.5" HDs Goffi 4 3,527 02-22-2022, 03:07 PM
Last Post: Goffi
  GNSS noise marcink 0 1,568 06-23-2021, 05:25 AM
Last Post: marcink
