Managing cpu voltage and clock speeds question.
(04-29-2021, 01:48 PM)QuinTeknoLife Wrote:
(12-31-2020, 03:10 AM)FeMike Wrote:
(12-25-2020, 12:04 AM)boteium Wrote: Changing cpu speed can be achieved via modifying file /sys/devices/system/cpu/cpufreq/policy0/scaling_max_freq and  /sys/devices/system/cpu/cpufreq/policy0/scaling_max_freq, assuming you are using schedutil scheduler. This process is the same regardless of which distribution you use or which arm device you use. As long as you're running linux, cpu speed can be altered this way. By the way, you should only use schedutil because this is a cpu with a mixture of big and little cores. Other cpu scheduler are not optimized to handle this big.little architecture the way schedutil does.
As for the cpu voltage, it cannot be changed during runtime. It can be changed via editing device tree but a reboot is needed for it to take effect. You will need to decompile /boot/dtbs/rockchip/rk3399-pinebook-pro.dtb, edit it, recompile it, and replace the original file.
Thank you. Very appreciative. I'll stick to the frequency thing and not mess with the voltage.
Soo, how did it go? Were you able to push the freq. at all? To what freq. were you able to push it (and how stable was it running)?  Tongue
look at my sig, pretty good OC i must say. Fun to toy around with it
PinebookPro v2.1 4xA53@1704Mhz / 2xA72@2208Mhz / GPU@1125Mhz / CCI-500@1200Mhz
RE: Managing cpu voltage and clock speeds question. - by generaleramon - 05-24-2021, 10:17 PM
  Question about graphics support mcc 11 15,543 10-10-2020, 06:43 AM
Last Post: sigmaris
  Question for GNOME3 users tophneal 23 24,846 03-13-2020, 06:09 AM
  OS development question vfr400racer 4 4,588 01-27-2020, 04:00 PM
Last Post: vfr400racer
  Question to anyone with entire system on NVMe as400 11 10,421 01-10-2020, 01:06 PM
  Quick Question Wayland vs X Jeremiah Cornelius 3 5,410 12-07-2019, 09:00 PM
Last Post: Samarium151
