pbp no longer boots
Blinking indicates a fault,,info,
https://www.ti.com/lit/ds/symlink/bq2417...52FBQ24171
Does it blink with usbC?
One person found that with a full charge with usbC, then barrel charger worked OK again
Yes, that is the mrfixit distro, the update is kernel and uboot, uboot IS installed
(IIRR /usr/bin/mrfixit_update.sh,, NOTE, only applies to THIS distro)
bind.... if you don't get switch timing right (emmc off,, 2 second window to switch on,, emmc is present)
then,, emmc switch on
echo fe330000.sdhci >/sys/bus/platform/drivers/sdhci-arasan/{un,}bind
But you don't need to do this, you have a charging problem, not a bad uboot on emmc problem
pbp no longer boots - by tulsums - 12-01-2020, 11:12 AM
RE: pbp no longer boots - by tophneal - 12-01-2020, 01:31 PM
RE: pbp no longer boots - by tulsums - 12-01-2020, 03:21 PM
RE: pbp no longer boots - by tulsums - 12-01-2020, 06:58 PM
RE: pbp no longer boots - by tophneal - 12-02-2020, 07:59 AM
RE: pbp no longer boots - by xyzzy - 12-02-2020, 02:07 PM
RE: pbp no longer boots - by KC9UDX - 12-01-2020, 08:56 PM
pbp no longer boots - by tophneal - 12-02-2020, 02:41 PM
RE: pbp no longer boots - by tulsums - 12-02-2020, 03:16 PM
RE: pbp no longer boots - by wdt - 12-02-2020, 06:36 PM
RE: pbp no longer boots - by tulsums - 12-03-2020, 08:16 AM
RE: pbp no longer boots - by xyzzy - 12-02-2020, 09:53 PM
RE: pbp no longer boots - by wdt - 12-03-2020, 11:29 AM
  Pinebook pro no longer boots xsquared93 7 7,559 02-13-2021, 09:39 AM
Shocked My pbp no longer boots sunjam 2 3,107 12-02-2020, 11:05 PM
Last Post: sunjam
  New Pinebook Pro, only boots 50% of the time micnd90 8 7,866 09-08-2020, 01:25 PM
Exclamation [SOLVED] PBP will no longer power on s3rvant 10 10,337 07-04-2020, 01:57 PM
Last Post: prokofiev
  emmc boots intermittently? haziz 7 7,331 06-08-2020, 07:22 PM
Last Post: mammbo3
