How are folks using the Pinephone (sim swapping?)
I found the instructions here, and followed it:
https://gitlab.com/mobian1/issues/-/issues/66
Once done, it started flickering between 4G and no connection a few times, and then:
エラー: 接続のアクティベーションに失敗: 不明なエラー
ヒント: 'journalctl -xe NM_CONNECTION=〇〇 + NM_DEVICE=cdc-wdm0' を使用して詳細を取得します。
Translation:
Error: Connection activation has failed: unknown error
Hint: Using 'journalctl -xe NM_CONNECTION=〇〇 + NM_DEVICE=cdc-wdm0', you can obtain details.
So I ran the command, and the logs are empty.
RE: How are folks using the Pinephone (sim swapping?) - by ryo - 12-02-2020, 01:07 AM
  Pinephone boot. Richy_T 2 51 7 hours ago
Last Post: zetabeta
  PinePhone - boot from microSD laserpyramid 9 838 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 418 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 283 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 110,692 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,918 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 659 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,495 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 536 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,779 12-22-2023, 03:44 PM
