Remove striped screw
#19
(12-06-2020, 09:31 AM)dsimic Wrote:
(11-21-2020, 08:20 PM)pizzalovingnerd Wrote: Hello, today I was trying to do the board swap, and I mistakenly stripped three screws.
What would be the easiest way to remove these screws?
Things I've tried so far:
Rubber band
Duck tape
Tacky glue
Super glue
JB Weld
Jamming in a Flathead
Have you tried using a left-hand drill bit?  That way you'd most probably be able to take the screws out without drilling out their heads completely.
Never use Super glue on striped screw, it just make the matter worse.
Remove striped screw - by pizzalovingnerd - 11-21-2020, 08:20 PM
RE: Remove striped screw - by bcnaz - 11-21-2020, 08:53 PM
RE: Remove striped screw - by pizzalovingnerd - 11-21-2020, 11:09 PM
RE: Remove striped screw - by bcnaz - 11-21-2020, 11:16 PM
RE: Remove striped screw - by pizzalovingnerd - 11-22-2020, 01:13 AM
RE: Remove striped screw - by bcnaz - 11-22-2020, 01:51 AM
RE: Remove striped screw - by pizzalovingnerd - 11-22-2020, 09:11 PM
RE: Remove striped screw - by User 18618 - 11-22-2020, 04:25 PM
RE: Remove striped screw - by KC9UDX - 11-22-2020, 07:48 PM
RE: Remove striped screw - by hiimtye - 11-22-2020, 09:36 PM
RE: Remove striped screw - by pizzalovingnerd - 11-23-2020, 11:14 AM
RE: Remove striped screw - by LazLong - 11-22-2020, 10:15 PM
RE: Remove striped screw - by hiimtye - 11-22-2020, 11:12 PM
RE: Remove striped screw - by bcnaz - 11-25-2020, 06:49 PM
RE: Remove striped screw - by RTP - 11-25-2020, 11:26 PM
RE: Remove striped screw - by bcnaz - 11-30-2020, 06:37 PM
RE: Remove striped screw - by hiimtye - 11-30-2020, 09:14 PM
RE: Remove striped screw - by dsimic - 12-06-2020, 09:31 AM
RE: Remove striped screw - by tllim - 12-08-2020, 02:22 PM
  DIY case backs, screw attachment biketool 1 1,986 04-07-2021, 10:07 AM
Last Post: wibble
  NO AFTER SALE SUPPORT --> After one week no way to remove batterie harvey186 19 19,781 05-17-2020, 02:01 PM
Last Post: 33YN2
