Remove striped screw
if it's just the end, use a tiny flat head and push it into the broken head, you may be able to screw it out without any extra effort. if not, take a small hammer and tap it into it until you make a tiny groove, then use the groove to screw it out
warning: you may damage your flat head in the process
Remove striped screw - by pizzalovingnerd - 11-21-2020, 08:20 PM
RE: Remove striped screw - by bcnaz - 11-21-2020, 08:53 PM
RE: Remove striped screw - by pizzalovingnerd - 11-21-2020, 11:09 PM
RE: Remove striped screw - by bcnaz - 11-21-2020, 11:16 PM
RE: Remove striped screw - by pizzalovingnerd - 11-22-2020, 01:13 AM
RE: Remove striped screw - by bcnaz - 11-22-2020, 01:51 AM
RE: Remove striped screw - by pizzalovingnerd - 11-22-2020, 09:11 PM
RE: Remove striped screw - by User 18618 - 11-22-2020, 04:25 PM
RE: Remove striped screw - by KC9UDX - 11-22-2020, 07:48 PM
RE: Remove striped screw - by hiimtye - 11-22-2020, 09:36 PM
RE: Remove striped screw - by pizzalovingnerd - 11-23-2020, 11:14 AM
RE: Remove striped screw - by LazLong - 11-22-2020, 10:15 PM
RE: Remove striped screw - by hiimtye - 11-22-2020, 11:12 PM
RE: Remove striped screw - by bcnaz - 11-25-2020, 06:49 PM
RE: Remove striped screw - by RTP - 11-25-2020, 11:26 PM
RE: Remove striped screw - by bcnaz - 11-30-2020, 06:37 PM
RE: Remove striped screw - by hiimtye - 11-30-2020, 09:14 PM
RE: Remove striped screw - by dsimic - 12-06-2020, 09:31 AM
RE: Remove striped screw - by tllim - 12-08-2020, 02:22 PM
  DIY case backs, screw attachment biketool 1 2,002 04-07-2021, 10:07 AM
Last Post: wibble
  NO AFTER SALE SUPPORT --> After one week no way to remove batterie harvey186 19 19,989 05-17-2020, 02:01 PM
Last Post: 33YN2
