Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit]
(06-05-2021, 01:10 AM)teneighty Wrote: This might be a bit of a tangent from the original purpose or the thread, but what does it take to get a SDDM login screen working?
I've not really done very much with Manjaro so I don't know any quick answer. On Slarm64 I built SDDM from source. Maybe the SDDM package that comes on the PinePhone has been altered or cut down? If so compiling it yourself might be the only option.
The sources are here: https://github.com/sddm/sddm
Or it could be another configuration thing.
https://wiki.archlinux.org/title/SDDM#Configuration
It's also worth taking a look in /var/log/sddm.log to see how far SDDM gets. On my PinePhone it got stuck interfacing with ConsoleKit but as you're on systemd that shouldn't be an issue.
It says here:
Quote:The configuration file for SDDM can be found at /etc/sddm.conf. See sddm.conf(5) for all options.
On systems controlled by systemd, everything should work out of the box  Dodgy , since SDDM defaults to using systemd-logind for session management. The configuration file will therefore not be created at package installation time. SDDM offers a command for generating a sample configuration file with the default settings if you really want one:
# sddm --example-config > /etc/sddm.conf
One other thing I had to do on Slarm64 is add an "sddm" user to the "video" group but on Manjaro I would've thought that would already be set up...
RE: Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] - by acid andy - 06-09-2021, 07:27 AM
  Using Signal on PinePhone in mid-2023? dante404 47 13,661 Today, 02:19 AM
Last Post: dragonhospital
  PinePhone app development WhiteHexagon 15 4,094 04-23-2024, 05:19 AM
Last Post: Jonnyc
Wink PINEPHONE not booting Touchwood 2 498 02-23-2024, 07:27 AM
Last Post: Touchwood
  Slack on PinePhone Adam Seline 5 5,463 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 24,736 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 2,091 11-23-2023, 01:06 AM
  openSUSE for Pinephone Alefnode 75 102,825 11-17-2023, 08:37 AM
Last Post: Uturn
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 1,019 11-04-2023, 07:23 PM
  Abiword as a office mobile word processor for the Pinephone? Peter Gamma 11 2,369 10-24-2023, 08:57 AM
  What File Manager Options Are There For The Pinephone? pinephoneuser22 7 2,499 10-18-2023, 08:37 AM
Last Post: luppivega
