Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit]
#32
While exploring other os's I noticed Maemo Leste has quite a bit of functionality as of late and it's based on Devuan which is possibly the only distribution besides Slack that is systemd free and it's my current desktop OS having left Slack because of the lack of mainstream app support.  In the install process (partial copy below) it has a step that seems may help with Slarm64.  I obviously don't know the in's and out's but if these steps are necessary then it seems they should be worked into the process.
eMMC Installation
Some notes have been adapted from the Pine64 Wiki.
Preparing the .img file for eMMC boot
Download the .img.xz version of the image and extract it:
$ unxz -k maemo-leste-*-arm64-pinephone-*.img.xz
The image, by default, points to
/dev/mmcblk0
for SD cards, which must be modified to point to
/dev/mmcblk2
for the eMMC. To start, mount the image to a loop device.
$ sudo losetup -P /dev/loop0 maemo-leste-*-arm64-pinephone-*.img
Mount the second partition to /mnt and the first partition to /mnt/boot and enter /mnt:
$ sudo mount /dev/loop0p2 /mnt
$ sudo mount /dev/loop0p1 /mnt/boot
$ cd /mnt
Use the editor of your choice to edit
/mnt/etc/fstab
, replacing
/dev/mmcblk0
with
/dev/mmcblk2
Now we need to edit
boot.scr
. For that you will need to download
boot.txt
from Maemo Leste github:
$ cd /mnt/boot
$ sudo wget https://raw.githubusercontent.com/maemo-...r/boot.txt
Now we do the same step as we did for the fstab, replacing
/dev/mmcblk0
with
/dev/mmcblk2
in
boot.txt
To regenerate
boot.scr
you need to install
u-boot-tools
first to be able to use mkimage.
Regenerate
boot.scr
$ sudo mkimage -A arm -O linux -T script -C none -a 0 -e 0 -d boot.txt boot.scr
RE: Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] - by donchurch - 03-21-2024, 10:52 AM
  Using Signal on PinePhone in mid-2023? dante404 47 14,041 05-03-2024, 02:19 AM
Last Post: dragonhospital
  PinePhone app development WhiteHexagon 15 4,197 04-23-2024, 05:19 AM
Last Post: Jonnyc
Wink PINEPHONE not booting Touchwood 2 540 02-23-2024, 07:27 AM
Last Post: Touchwood
  Slack on PinePhone Adam Seline 5 5,513 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 24,891 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 2,158 11-23-2023, 01:06 AM
  openSUSE for Pinephone Alefnode 75 103,173 11-17-2023, 08:37 AM
Last Post: Uturn
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 1,056 11-04-2023, 07:23 PM
  Abiword as a office mobile word processor for the Pinephone? Peter Gamma 11 2,430 10-24-2023, 08:57 AM
  What File Manager Options Are There For The Pinephone? pinephoneuser22 7 2,540 10-18-2023, 08:37 AM
Last Post: luppivega
