Axolotl on PinePhone / Mobian
(12-07-2020, 03:03 AM)marcih Wrote:
(12-06-2020, 01:49 PM)arno_nuehm Wrote:
(11-18-2020, 02:38 PM)marcih Wrote:
(11-17-2020, 11:51 AM)arno_nuehm Wrote:
(11-16-2020, 07:05 AM)marcih Wrote: Lucky you, I can't even get it to build, it always freezes at "npm install" when it's installing(?) node's rxjs. Has anybody gotten it to build successfully recently?
Is it really a "freeze" or is it just taking a bit more time? In my case (around 04.11.2020 - same date for the Mobian nightly image) it took quite a while for "npm install" to finish.
I'm not quite sure, I left it alone for half an hour or so with no progress, I assumed it was frozen since the little spinning line on the left wasn't moving either. I'll give it a try again tomorrow, leave it be for longer.
Have you tried it? I will have a go with a fresh installation of the fde-image in a few days and give you an update...
I have, with no luck. Interestingly, building the Flatpak went through fine so I don't know what the issue is. Either way, the app is currently not functional anyway, Electron crashes and qmlscene is not bundled in the Flatpak and doesn't seem to recognise the apt-installed copy.
With electron there is a known issues on arm64/aarch64 devices, I think. And Axolotl with qmlscene isn't working for me, too, I'm using it with the server flag and Firefox-esr as frontend. It's a work-around, but it works quite fine.
In a few days, I will try a fresh installation of Mobian/Axolotl and look into the qmlscene issues as well. Let's hope for the best.
Axolotl on PinePhone / Mobian - by arno_nuehm - 11-06-2020, 11:24 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 11-06-2020, 04:46 PM
RE: Axolotl on PinePhone / Mobian - by User 18618 - 11-11-2020, 04:25 PM
RE: Axolotl on PinePhone / Mobian - by marcih - 11-16-2020, 07:05 AM
RE: Axolotl on PinePhone / Mobian - by marcih - 11-16-2020, 10:32 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-17-2020, 11:51 AM
RE: Axolotl on PinePhone / Mobian - by marcih - 11-18-2020, 02:38 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-06-2020, 01:49 PM
RE: Axolotl on PinePhone / Mobian - by marcih - 12-07-2020, 03:03 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-07-2020, 04:20 AM
RE: Axolotl on PinePhone / Mobian - by marcih - 12-07-2020, 05:34 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-07-2020, 05:54 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-16-2020, 07:06 PM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 01-19-2021, 04:16 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 01-25-2021, 05:17 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 01-26-2021, 03:25 PM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 01-28-2021, 05:47 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 01-29-2021, 07:39 AM
RE: Axolotl on PinePhone / Mobian - by acm006 - 12-21-2020, 02:00 PM
RE: Axolotl on PinePhone / Mobian - by Ersatz - 12-21-2020, 08:38 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-22-2020, 04:59 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-01-2021, 08:48 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-01-2021, 12:11 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-01-2021, 02:32 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-02-2021, 02:54 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 02-03-2021, 03:27 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-04-2021, 04:05 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 02-04-2021, 04:34 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-05-2021, 04:51 AM
RE: Axolotl on PinePhone / Mobian - by kqlnut - 02-11-2021, 03:29 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-11-2021, 03:54 AM
RE: Axolotl on PinePhone / Mobian - by kqlnut - 02-11-2021, 04:05 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-11-2021, 08:48 AM
RE: Axolotl on PinePhone / Mobian - by kqlnut - 02-11-2021, 11:01 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-11-2021, 03:58 PM
RE: Axolotl on PinePhone / Mobian - by RTP - 02-11-2021, 04:35 PM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 02-12-2021, 04:35 PM
RE: Axolotl on PinePhone / Mobian - by marcih - 02-13-2021, 03:11 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 02-13-2021, 05:47 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-13-2021, 08:04 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-25-2021, 06:22 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 02-25-2021, 09:16 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-27-2021, 06:24 AM
RE: Axolotl on PinePhone / Mobian - by ergo owl - 03-06-2021, 02:51 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 03-06-2021, 04:56 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 03-09-2021, 04:25 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 03-09-2021, 05:51 AM
RE: Axolotl on PinePhone / Mobian - by Pelecanus - 03-17-2021, 02:31 PM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 03-17-2021, 03:15 PM
RE: Axolotl on PinePhone / Mobian - by Pelecanus - 03-18-2021, 06:46 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 03-18-2021, 11:07 AM
RE: Axolotl on PinePhone / Mobian - by Pelecanus - 03-18-2021, 12:30 PM
RE: Axolotl on PinePhone / Mobian - by Anna - 03-18-2021, 02:12 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 03-19-2021, 03:56 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 03-19-2021, 06:10 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 03-19-2021, 06:24 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 03-19-2021, 06:32 AM
RE: Axolotl on PinePhone / Mobian - by Pelecanus - 03-19-2021, 08:42 AM
RE: Axolotl on PinePhone / Mobian - by RTP - 03-15-2021, 03:54 PM
RE: Axolotl on PinePhone / Mobian - by Anna - 03-19-2021, 10:21 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 04-05-2021, 12:48 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-13-2021, 05:59 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-28-2021, 12:42 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-28-2021, 01:45 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-28-2021, 02:26 PM
One single contact broken in Axolotl - by Anna - 05-06-2021, 04:08 AM
RE: Axolotl on PinePhone / Mobian - by Avatars - 05-10-2021, 07:07 AM
RE: Axolotl on PinePhone / Mobian - by ergo owl - 05-13-2021, 05:38 AM
RE: Axolotl on PinePhone / Mobian - by Avatars - 05-13-2021, 05:42 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 05-14-2021, 05:50 AM
RE: Axolotl on PinePhone / Mobian - by richieeee - 05-20-2021, 01:31 PM
RE: Axolotl on PinePhone / Mobian - by Cree - 05-20-2021, 12:30 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 05-28-2021, 07:52 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 06-02-2021, 12:36 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 06-02-2021, 05:42 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 06-03-2021, 03:57 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 06-03-2021, 11:06 AM
RE: Axolotl on PinePhone / Mobian - by ergo owl - 06-11-2021, 07:16 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 06-23-2021, 08:13 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 07-06-2021, 02:34 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 07-12-2021, 01:46 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-10-2021, 05:19 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 07-20-2021, 02:09 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 07-20-2021, 01:34 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 07-21-2021, 02:39 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 07-21-2021, 02:35 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 07-23-2021, 12:32 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-27-2021, 06:36 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-28-2021, 05:23 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-28-2021, 07:55 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-04-2021, 07:40 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-06-2021, 02:29 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-16-2021, 08:22 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 09-16-2021, 11:15 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 09-16-2021, 02:19 PM
RE: Axolotl on PinePhone / Mobian - by Anna - 09-17-2021, 01:21 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-17-2021, 02:36 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-26-2021, 10:21 AM
RE: Axolotl on PinePhone / Mobian - by juju - 09-26-2021, 07:12 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-27-2021, 01:58 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 09-30-2021, 04:40 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 10-21-2021, 01:24 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 10-21-2021, 01:57 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 10-28-2021, 09:44 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 11-04-2021, 02:02 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 11-17-2021, 10:18 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-17-2021, 10:38 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 11-17-2021, 02:14 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-17-2021, 03:02 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-19-2021, 02:54 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-23-2021, 02:43 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 11-24-2021, 11:34 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-24-2021, 11:48 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 11-24-2021, 02:46 PM
RE: Axolotl on PinePhone / Mobian - by dante404 - 11-23-2021, 09:34 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 11-29-2021, 07:34 AM
RE: Axolotl on PinePhone / Mobian - by kqlnut - 11-29-2021, 10:36 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-29-2021, 11:56 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-30-2021, 03:47 PM
RE: Axolotl on PinePhone / Mobian - by Anna - 12-02-2021, 03:09 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 12-03-2021, 04:36 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-06-2021, 11:29 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 12-06-2021, 12:00 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-06-2021, 12:48 PM
RE: Axolotl on PinePhone / Mobian - by Anna - 12-12-2021, 02:46 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-12-2021, 12:57 PM
RE: Axolotl on PinePhone / Mobian - by ichbins - 12-16-2021, 01:14 PM
RE: Axolotl on PinePhone / Mobian - by eFqLLnGo - 12-17-2021, 05:25 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 01-20-2022, 06:24 AM
RE: Axolotl on PinePhone / Mobian - by DominiqueM - 01-20-2022, 08:06 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 01-21-2022, 04:45 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-01-2022, 01:05 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-13-2022, 04:33 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 02-16-2022, 04:18 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-16-2022, 04:41 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 03-15-2022, 05:57 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 03-17-2022, 03:41 AM
RE: Axolotl on PinePhone / Mobian - by user641 - 03-17-2022, 04:40 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 03-17-2022, 11:43 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 04-04-2022, 07:43 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-04-2022, 09:03 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 04-05-2022, 05:40 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-05-2022, 06:30 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-14-2022, 03:16 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-09-2022, 02:10 PM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 08-11-2022, 02:28 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-15-2022, 11:26 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-19-2022, 01:33 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 08-20-2022, 07:47 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-23-2022, 04:17 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 08-23-2022, 09:37 AM
RE: Axolotl on PinePhone / Mobian - by Eugo - 09-04-2022, 06:50 AM
RE: Axolotl on PinePhone / Mobian - by shulamy - 09-04-2022, 07:10 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 09-04-2022, 11:41 AM
RE: Axolotl on PinePhone / Mobian - by Eugo - 09-05-2022, 11:00 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-05-2022, 02:24 PM
RE: Axolotl on PinePhone / Mobian - by shulamy - 09-05-2022, 12:55 AM
RE: Axolotl on PinePhone / Mobian - by Eugo - 09-06-2022, 12:33 AM
RE: Axolotl on PinePhone / Mobian - by shulamy - 09-06-2022, 01:00 AM
RE: Axolotl on PinePhone / Mobian - by Eugo - 09-08-2022, 05:24 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-11-2022, 05:35 PM
RE: Axolotl on PinePhone / Mobian - by Eugo - 09-12-2022, 02:55 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 10-17-2022, 09:01 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 10-27-2022, 01:51 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 10-27-2022, 03:31 PM
RE: Axolotl on PinePhone / Mobian - by dante404 - 10-28-2022, 05:17 AM
RE: Axolotl on PinePhone / Mobian - by Eugo - 10-29-2022, 09:16 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 10-31-2022, 04:56 AM
RE: Axolotl on PinePhone / Mobian - by Eugo - 11-01-2022, 05:22 AM
RE: Axolotl on PinePhone / Mobian - by benedikt55 - 11-01-2022, 08:10 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-01-2022, 04:02 PM
RE: Axolotl on PinePhone / Mobian - by Eugo - 11-02-2022, 08:43 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 11-08-2022, 09:18 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-08-2022, 03:08 PM
RE: Axolotl on PinePhone / Mobian - by benedikt55 - 11-09-2022, 04:02 PM
RE: Axolotl on PinePhone / Mobian - by dante404 - 11-10-2022, 02:12 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-10-2022, 02:40 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 01-23-2023, 03:46 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 01-24-2023, 02:07 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 01-27-2023, 02:54 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 01-27-2023, 04:38 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 01-27-2023, 04:52 AM
RE: Axolotl on PinePhone / Mobian - by zetabeta - 01-27-2023, 07:06 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 01-27-2023, 06:08 PM
RE: Axolotl on PinePhone / Mobian - by dante404 - 01-29-2023, 10:52 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 02-07-2023, 02:19 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 03-13-2023, 09:14 AM
RE: Axolotl on PinePhone / Mobian - by shulamy - 03-22-2023, 12:05 AM
RE: Axolotl on PinePhone / Mobian - by zetabeta - 03-22-2023, 04:17 AM
RE: Axolotl on PinePhone / Mobian - by shulamy - 03-22-2023, 04:58 AM
RE: Axolotl on PinePhone / Mobian - by zetabeta - 03-22-2023, 10:48 AM
RE: Axolotl on PinePhone / Mobian - by shulamy - 03-26-2023, 01:49 AM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 21 2,168 9 hours ago
Last Post: anonymous
  Mobian repository status henrythemouse 16 8,831 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 140 03-18-2024, 08:54 PM
Last Post: penguins_rule
  unofficial kali linux for pinephone help needed pinesmell 5 3,666 01-08-2024, 02:50 PM
Last Post: ERPlegend
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,022 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,843 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 643 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,948 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,912 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 639 07-05-2023, 03:57 AM
Last Post: paulcarton
