2 out of 4 boards present a problem with internet (ethernet)
(05-27-2016, 01:45 PM)longsleep Wrote: rx-delay seems to be ok as 0.
tx-delay is 3 by default in my builds. In Android i think it is 2. Try modifying tx-delay only and keep the value between 0 and 7. Valid range for rx-delay is 0-31.
Also note that the values for rx and tx-delay are to be given as hex (base 16).
Following those instructions i played around as suggested (Thanks to longsleep), but there was no improvement, mainly it got worse. Even receiving speed (iperf3 -c ...) got worse by changing tx-delay above 3. tx-delay 2 was (sometimes) best, but still a lot of retries in iperf and not stable.
Switching back to a fixed 100mbit setting with original .dtb works flawless for me, only some retries as client and none as server and stable about 95mbits, so fine for me at the moment.
If anyone likes to change his running 1000mbit board with mine to proof i'm doing something wrong here, i'm glad to help [emoji6]
Gesendet von meinem K00L mit Tapatalk
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
RE: 2 out of 4 boards present a problem with internet (ethernet) - by androsch - 05-29-2016, 09:18 AM
  Connected to Wifi but no Internet pnoyrocket 2 5,637 11-22-2020, 06:23 AM
Last Post: Little_Johnny
  Pine 64 + WIFI - OVERHEAT problem Berkut 0 3,269 10-24-2018, 12:52 PM
Last Post: Berkut
  Possible to simultaneously connect to ethernet & wi-fi? wahdooyah 3 4,598 01-26-2018, 06:57 PM
Last Post: dkryder
  2nd ethernet in PINE64 with android daniele 2 4,098 12-07-2017, 05:09 AM
Last Post: daniele
  No Ethernet on Andriod rvalecruz 5 6,750 05-05-2017, 01:59 AM
Last Post: Quezbeme
  My Hacky ethernet fix anarchyuk 21 31,290 11-20-2016, 12:01 PM
Last Post: waldo
  Lost Ethernet hatman28 13 17,180 11-10-2016, 09:05 PM
Last Post: pfeerick
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 23,969 10-29-2016, 04:31 AM
Last Post: joe
  Guest Account Cannot Access Internet on Remix OS and Android x-86 OS deniyulianti 1 3,118 10-21-2016, 05:38 AM
Last Post: MarkHaysHarris777
  Guest Account in Android x-86 OS cannot Access Internet deniyulianti 0 2,153 10-15-2016, 07:30 AM
Last Post: deniyulianti
