2 out of 4 boards present a problem with internet (ethernet)
I got my order 2 days ago and first thing I did was to try if everything works right.
I got 4 Pines (2GGB version).
After I successfully created 3 Sandisk 16GB (uhs-1 uU3) android sd cards with the latest build, I started testing them
All 4 booted flawlessly within seconds. However, only 2 of them can browse the internet and connect to Play Store.
They do get an IP assigned while date and time get also synchronized, nevertheless it is like if they are not connected to the internet at all! I'm unable to browse any site (not even Google) and Play Store displays connection error.
After I saw this behaviour by 2 of my Pines, I decided I will run all 4 under the same circumstances (same 20awg usb lead, Anker 2.4A PSU, connected to my Gigabit switch with a specific 50cm Cat7 Ethernet cable, same microSD)
The same 2 that initially had problems, persisted the same behaviour (got IP and date/time but no internet)
I subsequently tried the Wifi/BT module with those 2 and successfully connected to the internet.
At this point, I started believing there is a problem with their Gigabit chip. It was then that I thought I had to try another OS. I burnt an image with xbuntu (latest longsleep's version). The 2 specific Pines booted within seconds and connected to the internet successfully. I browsed the internet with Pidora and they were quite responsive.
However, when I tried a speed test (speedtest.net) I got only 0.5/5 and 5/5 respectively while my usual speeds are 74/5.
That said, upload speed doesn't seem to be affected. Download is hammered though!
I have seen some users recommending one should push the Gigabit network to 100Mbit in order to achieve decent download speeds. Despite I don't know how am I supposed to be doing this, I am willing to try.
The question is why 2 of my Pines perform excellent within my Gigabt network while the other 2 don't?
Is there a possibility those 2 being faulty? With just 30 days of warranty I don't have much time to experiment or wait for updates. If there is no solution soon I'll have to send those 2 back as they clearly underperform under pretty much all conditions.
ANY RECOMMENDATIONS BEFORE I PRONOUNCE THEM FAULTY?
By the way the board exceeded my expectations. I was expecting something MUCH WORSE judging by all these posts lately with dozens of different problems users have faced as of now. However, latest Android works really smooth and fast for me with no crashes whatsoever. I can see smooth 1080p YouTube videos through YouTube app and browsing the internet is flawless. Ubuntu worked also quite well during the few minutes I tested it. I suggest all those who face any kind of problems to use a good quality SD card, burn a rooted DD image of the size of their card with Win32diskimager, use short 20AWG charging cables and a known-branded PSU rated over 2A. Provided you do all these, I doubt you will have problems or instability issues.
Good job guys. I can see some serious potential on the Pine. This thing can only get better from now on!
2 out of 4 boards present a problem with internet (ethernet) - by g_t_j - 05-26-2016, 03:16 PM
  Connected to Wifi but no Internet pnoyrocket 2 5,650 11-22-2020, 06:23 AM
Last Post: Little_Johnny
  Pine 64 + WIFI - OVERHEAT problem Berkut 0 3,273 10-24-2018, 12:52 PM
Last Post: Berkut
  Possible to simultaneously connect to ethernet & wi-fi? wahdooyah 3 4,610 01-26-2018, 06:57 PM
Last Post: dkryder
  2nd ethernet in PINE64 with android daniele 2 4,108 12-07-2017, 05:09 AM
Last Post: daniele
  No Ethernet on Andriod rvalecruz 5 6,764 05-05-2017, 01:59 AM
Last Post: Quezbeme
  My Hacky ethernet fix anarchyuk 21 31,357 11-20-2016, 12:01 PM
Last Post: waldo
  Lost Ethernet hatman28 13 17,254 11-10-2016, 09:05 PM
Last Post: pfeerick
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 24,027 10-29-2016, 04:31 AM
Last Post: joe
  Guest Account Cannot Access Internet on Remix OS and Android x-86 OS deniyulianti 1 3,124 10-21-2016, 05:38 AM
Last Post: MarkHaysHarris777
  Guest Account in Android x-86 OS cannot Access Internet deniyulianti 0 2,159 10-15-2016, 07:30 AM
Last Post: deniyulianti
