What are the actual supported framerate/resolution pairs for the PBP webcam?
Here's something I'd like to know. What are the actual supported framerates/resolution pairs for the pinebook pro's webcam?
v4l2-ctl --list-formats-ext gives
ioctl: VIDIOC_ENUM_FMT
    Type: Video Capture
    [0]: 'YUYV' (YUYV 4:2:2)
            Interval: Discrete 0.100s (10.000 fps)
            Interval: Discrete 0.200s (5.000 fps)
        Size: Discrete 1600x1200
            Interval: Discrete 0.050s (20.000 fps)
            Interval: Discrete 0.067s (15.000 fps)
which suggests that the camera is capable of a pretty good framerate at 1600x1200. But I haven't figured out how to actually achieve this frame rate at this resolution. The higher resolution seems to default to quite long exposures, which might have something to do with it, although setting absolute exposure manually affects brightness but doesn't seem to effect the "blur" effect that the long exposures create.
Testing with external webcams tentatively suggests that the bottleneck isn't the power of the pbp---you can get smooth 30fps playback of the video feed there, in the same output format (YU12-YU12, according to guvcview, although maybe there's some subtle thing here that I'm missing) that the pbp's camera produces.
Anyway I'm just very curious about 1. what the actual capacities of this camera are, and 2. whether we might hope to see better fps at high resolution in the future, with better driver support, or with the right software configuration.
What are the actual supported framerate/resolution pairs for the PBP webcam? - by gleachkr - 09-15-2020, 09:47 AM
  Which application can I use to test webcam? richfm 11 14,373 02-13-2020, 06:34 AM
Last Post: as400
  Wrong resolution on external monitor vfr400racer 2 3,490 01-11-2020, 04:46 PM
Last Post: regivanx
