09-15-2020, 08:17 PM
(09-12-2020, 05:26 PM)brentashley Wrote:(09-12-2020, 01:19 PM)guenther Wrote: There is a function in the settings to go back to "factory image". If that does not work you can use "jumpdrive" (wiki-> pinephone-> jumpdrive) or UB Ports "command mode" (hold down the volume button while starting) to write the image to the emmc(internal).
Use the search function to look for detailed explanations and links.
I did the reset from settings, but it just cleared the user partition, and I had remounted the root partition and installed some things that remained after the reset. Looks like jumpdrive will be necessary for a full reset.
I have tried Jumpdrive but I am unable to get it to boot. I used dd on my mac to flash it as instructed, I can see the files on it when I mount it on the mac, but it doesn't get past the initial indication of turning the screen's backlight on when booting. I have tried version 0.5 and 0.4, and both using DD and Etcher to flash it with the same result. Will now try command mode, first looking for explanations.
