libertine and desktop apps
(09-12-2020, 10:33 AM)m4xx3d0ut Wrote: Just got my Pinetab, seriously impressed with build quality and usability out of the box, but has anyone had success with libertine?  I just started poking around it and I'm looking for good sources of information on lxc and lxd containers.  I could be missing something but I've been trying to get FireFox to work with little success as of yet.  I'm going to spend a bit of time on it today to see what I can sort out from the console output.
I am just trying it today from a command line. I couldn't get the GUI to work but the CLI works OK -- maybe.
From a terminal:
libertine-container-manager create -i TEST
libertine-container-manager install-package -i test -p gimp
I do get some kind of proot warning about /run/shm too many levels of symbolic links.
That puts a Gimp icon on the launcher but doesn't seem to want to run from the GUI or using libertine-launch that I can figure out yet.
Update:
So there appear to be multiple ways to run:
libertine-launch -i test gimp
ubuntu-app-launch test_gimp_0.0 # tab completion works
libertine-container-manager exec -i test -c "gimp"
None of these work because they can't find Xmir (or libertine-xmir) running. But you can do something like:
dbus-launch libertine-launch -i test ls /etc
The dbus part seems critical, though. Without it, you can't find the maliit input method stuff. Not sure why. But if you replace the ls with gimp, you can't find the Xmir display. The Wayland socket appears to be in /var/run/user/####/wayland-0 and the ##### part is always 32011 for me, but not sure if that's always true....
Update 2. As far as I can tell, the issue is that Xmir expects Mir and we have Wayland. So while it is looking for mir_socket, we have wayland-0. I doubt just plumbing them together would do anything.
libertine and desktop apps - by m4xx3d0ut - 09-12-2020, 10:33 AM
RE: libertine and desktop apps - by wd5gnr - 09-12-2020, 11:05 AM
RE: libertine and desktop apps - by peperjohnny - 09-15-2020, 12:07 AM
  Favourite desktop environment discussion FortunateFowl 6 1,799 09-02-2023, 07:38 AM
Last Post: lllll
  No desktop after latest updates (Jun 16, 2023) rqkeating 5 1,729 06-21-2023, 04:16 PM
Last Post: rqkeating
  Important apps stopped working yurievitch 2 4,530 07-14-2021, 11:43 PM
Last Post: LisaFord
  Arch, Plasma desktop and wayland peperjohnny 49 60,840 06-10-2021, 08:31 AM
Last Post: peperjohnny
  PineTab Mobian LXDE desktop fjord 0 2,274 02-24-2021, 06:32 PM
Last Post: fjord
