First impressions
#51
(09-08-2020, 12:58 PM)guenther Wrote: Overall it looks very good. Tried to find out if a screen protector is installed (Yes it is)  and by putting it back I pressed on the corner of the screen what causes the corner to bend (and stays bend). Seems the whole screen is made of plastic?
Did an update of UT and installed Dekko2, what causes crashes.  Can't find an other email client for UT!?
Flashed Mobian to SD and booted. Looks promising but not ready. No sound, twisted screen...back to UT
After some hours the wifi stopped working, did an system reset in the settings app. wifi works again.
(09-08-2020, 10:57 AM)eaglecup Wrote: But I noticed the device reports having just 14Gb of storage. The specs say it should have 64? I hope this is just a software problem.
Same here. I guess the partition needs to be expanded. Will try tomorrow....
Edit: I putted the PineTab into "command mode" by holding down the volume button while starting the device. It showed "awaiting command". Connected it to my linux laptop over usb and expanded the home partition with gparted. UT shows 61.2 GB total storage now.
Is there documentation on "command mode" and what exactly needs to be done? I keep trying to hold "volume down" + "power" and it just boots into OS. Do I need to have a USB connection to my computer before I do that? I have tried it with and without. Does it only work on a certain port? I'm currently using the micro usb connection to usb a on my laptop.
First impressions - by eaglecup - 09-08-2020, 10:29 AM
RE: First impressions - by tophneal - 09-08-2020, 10:45 AM
RE: First impressions - by eaglecup - 09-08-2020, 10:57 AM
RE: First impressions - by tophneal - 09-08-2020, 11:21 AM
RE: First impressions - by Ktaadn - 09-08-2020, 12:18 PM
RE: First impressions - by guenther - 09-08-2020, 12:58 PM
RE: First impressions - by blabux - 09-12-2020, 08:06 PM
RE: First impressions - by guenther - 09-13-2020, 01:43 AM
RE: First impressions - by GreyLinux - 09-08-2020, 01:51 PM
RE: First impressions - by gimy16 - 09-08-2020, 03:29 PM
RE: First impressions - by hexdump - 09-08-2020, 11:40 PM
RE: First impressions - by bartgrefte - 09-09-2020, 03:19 AM
RE: First impressions - by hexdump - 09-09-2020, 04:48 AM
RE: First impressions - by andybleaden@gmail.com - 09-09-2020, 05:43 AM
RE: First impressions - by Ktaadn - 09-09-2020, 06:04 AM
RE: First impressions - by guenther - 09-09-2020, 06:30 AM
RE: First impressions - by Ktaadn - 09-09-2020, 06:45 AM
RE: First impressions - by andybleaden@gmail.com - 09-09-2020, 07:56 AM
RE: First impressions - by Ktaadn - 09-09-2020, 08:03 AM
RE: First impressions - by andybleaden@gmail.com - 09-09-2020, 08:06 AM
RE: First impressions - by guenther - 09-09-2020, 09:27 AM
RE: First impressions - by andybleaden@gmail.com - 09-09-2020, 09:51 AM
RE: First impressions - by guenther - 09-09-2020, 10:12 AM
RE: First impressions - by ashley123 - 09-09-2020, 12:40 PM
RE: First impressions - by eaglecup - 09-09-2020, 03:12 PM
RE: First impressions - by peperjohnny - 09-10-2020, 01:13 AM
RE: First impressions - by mattpenn - 09-09-2020, 03:27 PM
RE: First impressions - by bartgrefte - 09-10-2020, 03:15 AM
RE: First impressions - by pjsf - 09-10-2020, 03:22 AM
RE: First impressions - by eaglecup - 09-10-2020, 03:43 AM
RE: First impressions - by andybleaden@gmail.com - 09-10-2020, 05:16 AM
RE: First impressions - by sunrunner - 09-11-2020, 03:42 AM
RE: First impressions - by Paraplegic Racehorse - 09-11-2020, 10:17 AM
RE: First impressions - by mithbre - 09-11-2020, 09:26 PM
RE: First impressions - by bartgrefte - 09-11-2020, 10:39 AM
RE: First impressions - by wispoffates - 09-11-2020, 10:41 AM
RE: First impressions - by guenther - 09-11-2020, 01:54 PM
RE: First impressions - by quipacorn - 09-11-2020, 12:26 PM
RE: First impressions - by bartgrefte - 09-11-2020, 12:44 PM
RE: First impressions - by Paraplegic Racehorse - 09-11-2020, 01:15 PM
RE: First impressions - by tophneal - 09-11-2020, 08:50 PM
RE: First impressions - by andybleaden@gmail.com - 09-12-2020, 12:58 AM
RE: First impressions - by GreyLinux - 09-11-2020, 03:35 PM
RE: First impressions - by n3rDy - 09-11-2020, 08:22 PM
RE: First impressions - by wd5gnr - 09-11-2020, 09:50 PM
RE: First impressions - by wd5gnr - 09-11-2020, 10:07 PM
RE: First impressions - by sunrunner - 09-12-2020, 12:52 AM
RE: First impressions - by wd5gnr - 09-12-2020, 07:16 AM
RE: First impressions - by GreyLinux - 09-12-2020, 08:03 AM
RE: First impressions - by wd5gnr - 09-12-2020, 09:04 AM
RE: First impressions - by ImaPagan - 09-12-2020, 11:51 AM
RE: First impressions - by mindwave - 09-12-2020, 03:57 PM
RE: First impressions - by rocket2nfinity - 09-13-2020, 06:22 AM
RE: First impressions - by mithbre - 09-13-2020, 12:43 PM
RE: First impressions - by mike-451 - 09-13-2020, 08:40 PM
RE: First impressions - by mike-451 - 09-14-2020, 07:15 PM
RE: First impressions - by mindwave - 09-16-2020, 10:33 AM
RE: First impressions - by rocket2nfinity - 09-16-2020, 05:31 PM
RE: First impressions - by eaglecup - 09-20-2020, 09:35 AM
RE: First impressions - by mindwave - 09-30-2020, 02:22 AM
RE: First impressions - by dhosh - 09-20-2020, 07:40 PM
RE: First impressions - by Pinoideae - 09-23-2020, 04:33 PM
RE: First impressions - by Jeffersoniantoo - 10-04-2020, 07:39 AM
RE: First impressions - by jazzmans - 10-06-2020, 06:18 PM
RE: First impressions - by Mr_Yuzu - 10-06-2020, 07:07 PM
RE: First impressions - by jazzmans - 10-06-2020, 07:52 PM
RE: First impressions - by lennie - 10-07-2020, 06:18 PM
RE: First impressions - by jazzmans - 10-08-2020, 01:33 AM
RE: First impressions - by mindwave - 10-11-2020, 03:55 PM
RE: First impressions - by demure - 10-13-2020, 10:23 PM
  Initial Impressions dachalife 6 2,102 06-09-2023, 11:48 AM
Last Post: dachalife
  Pinetab2 - First impressions Surehand53 6 5,521 06-07-2023, 04:50 PM
Last Post: zer0sig
