Segfault with GCC in Armbian [Solved].
To continue this story of over and under clocking memory for stability.  Here is a graph showing the relative memory bandwidth of the Rock64  with different memory clock speeds.
[Image: rock64_400.svg]
Again both of the Rock64 single-board computers I have seem stable with the memory clock set to 400 MHz. Since the errors at 786 MHz are intermittent, my guess is the memory could still go a little faster, perhaps 600 MHz or even 666 MHz.
Does anyone know how to make uboot files which initialize the memory at 600 or 666 MHz?
RE: One works the other doesn't. - by ejolson - 08-31-2020, 01:48 PM
RE: One works the other doesn't. - by Rocklobster - 08-31-2020, 08:54 PM
RE: One works the other doesn't. - by ejolson - 09-01-2020, 10:02 PM
RE: One works the other doesn't. - by t4_4t - 08-31-2020, 09:45 PM
RE: One works the other doesn't. - by ejolson - 09-02-2020, 09:11 AM
RE: One works the other doesn't. - by ejolson - 09-02-2020, 02:09 PM
RE: One works the other doesn't. - by tomarm - 09-01-2020, 12:30 AM
RE: One works the other doesn't. - by ejolson - 09-04-2020, 08:58 PM
RE: Segfault with GCC in Armbian [Solved]. - by ejolson - 09-05-2020, 01:57 PM
  Rock64 No Audio - Solved wbecks 12 30,321 08-13-2021, 01:23 PM
Last Post: blakeadam
  Rock64-4gb,Armbian Debian Stretch: Plex, Radarr, NZBGet and Sickchill WOW Baracuda2 1 3,066 02-27-2019, 03:34 PM
Last Post: Luke
  [SOLVED] stuck at emmc dr_dre 10 12,695 04-29-2018, 05:10 PM
Last Post: pfeerick
  Solved - When did you order your Rock64 rhille 5 7,111 08-25-2017, 07:17 AM
Last Post: rhille
