Changing the ringtone?
(02-25-2021, 08:45 PM)Zebulon Walton Wrote: I just tried this and now I have no ringtone at all. Sad
Rebooted and still no ringtone. So then I tried setting the dconf-editor setting back to what it was (__custom) and still nothing, just vibration on incoming calls. (That dconf-editor is a bit tough to use on the pinephone screen!) I made sure system sounds are turned on in the Settings program, and the custom .oga files play on the Pinephone using mplayer. Any ideas what might be wrong? Or how to get back the configuration from before I messed with this? (I have a full backup.) I've used dconf-editor before but have no idea where it actually stores its settings.
I don't know if this will help, but after my custom sounds stopped working on the Pinetab (mobian), I noticed in Settings -> Sound -> Output that 'output' was actually set to the microphone. Switching it back to the internal speaker made sounds play again. I have no idea when/how the setting changed in the first place.
As for where dconf-editor stores changes, pretty sure it is in the binary file ~/.config/dconf/user.
Changing the ringtone? - by Hiraghm - 08-30-2020, 03:30 PM
RE: Changing the ringtone? - by bcnaz - 08-30-2020, 03:41 PM
RE: Changing the ringtone? - by DarkManiels - 08-31-2020, 08:09 AM
RE: Changing the ringtone? - by gab - 10-08-2021, 11:05 AM
RE: Changing the ringtone? - by county93 - 10-08-2021, 10:01 PM
RE: Changing the ringtone? - by Maynard - 11-16-2020, 10:42 PM
RE: Changing the ringtone? - by Zebulon Walton - 02-25-2021, 08:45 PM
RE: Changing the ringtone? - by sbeaugrand - 03-25-2021, 01:38 AM
RE: Changing the ringtone? - by zounds - 03-30-2021, 10:54 AM
RE: Changing the ringtone? - by gab - 10-10-2021, 09:48 AM
  Changing Desktop Environments? Ferriah 14 8,861 01-20-2022, 06:58 AM
  Customizing the ringtone spaetz 2 3,110 03-13-2021, 02:48 PM
Last Post: ergo owl
  How to change the minimum password length when changing from default passwords arturo2bodegas 3 4,633 07-18-2020, 01:51 PM
Last Post: arturo2bodegas
