[SOLVED] Brand new pinephone bricked almost immediately out of box...
(07-31-2020, 10:15 AM)Cree Wrote:
(07-30-2020, 12:02 PM)wibble Wrote:
(07-30-2020, 07:36 AM)Danct12 Wrote:
(07-26-2020, 02:19 PM)Cree Wrote: Would be good if the pinephone prompted you on startup as to whether you intend to boot from eMMC or SD card
That is unfortunately impossible as A64 boot order is SD first, then eMMC.
Well...you'd need the u-boot on the SD to have the option to boot whatever's on the eMMC. Since uBoot can't write to this display you'd have to make the choice using the volume and power buttons, possibly using the LED as an indicator. I've not got round to making up a serial cable to investigate further.
Or have a kernel and initrd on the SD that can load and kexec from partitions on the eMMC or SD.
Great idea! Worth further digging. Unfortunately unless something like this is done we're not going to have expandable storage. Sure we can always flash new larger SD cards, but we'd always need to set up all our personal stuff from scratch. A way to keep the OS on eMMC and have storage on SD would truly be ideal.
That's actually a whole lot easier since you don't need to get user input, just use a uboot config on the SD that boots the eMMC. I'm not sure even that's necessary though - i think you just have to make sure there's no bootloader in the boot sector of the SD, causing it to fall back to booting from the eMMC.
RE: [SOLVED] Brand new pinephone bricked almost immediately out of box... - by wibble - 07-31-2020, 01:51 PM
  Using Signal on PinePhone in mid-2023? dante404 47 15,069 05-03-2024, 02:19 AM
Last Post: dragonhospital
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 38 25,990 04-23-2024, 10:29 AM
Last Post: donchurch
  PinePhone app development WhiteHexagon 15 4,491 04-23-2024, 05:19 AM
Last Post: Jonnyc
Wink PINEPHONE not booting Touchwood 2 602 02-23-2024, 07:27 AM
Last Post: Touchwood
  Slack on PinePhone Adam Seline 5 5,610 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 25,546 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 2,287 11-23-2023, 01:06 AM
  openSUSE for Pinephone Alefnode 75 103,887 11-17-2023, 08:37 AM
Last Post: Uturn
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 1,121 11-04-2023, 07:23 PM
  Abiword as a office mobile word processor for the Pinephone? Peter Gamma 11 2,638 10-24-2023, 08:57 AM
