Latest Installer Image hangs after updates
I used the latest 2020-Jul-16 12:26 image and was able to burn and SD card then go through the installation.  Once the installation completed and rebooted I went to the Software application and chose updates.  I got an initial error message about a Gnome component which I closed out then it showed all the updates.  I applied all the updates and rebooted.  Now it just hangs with a white/green/purple LED cycling.  I have tried this twice on two different SD cards with the same result.
Is this expected or have others noticed the same behavior?
Latest Installer Image hangs after updates - by u20200719 - 07-19-2020, 08:39 PM
  Firefox Crashes on Start-up (latest installer) & How do I change Default Browser? aLoop100o 1 519 11-22-2023, 10:16 AM
Last Post: zetabeta
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 900 10-03-2023, 06:32 PM
  Issues after installing latest PostMarket OS with POSH xen314 4 1,535 08-20-2023, 11:18 PM
Last Post: xen314
  how to install updates? someGermanGuy 2 2,034 04-26-2022, 12:48 PM
Last Post: someGermanGuy
  Latest suggestion to fix modem instability? feklee 10 8,917 01-31-2022, 01:16 PM
Last Post: feklee
  Latest build no firefox, text editor? cosmicschock 2 2,375 10-03-2021, 12:19 PM
Last Post: cosmicschock
  Where is the original PM OS image for Pinephone? mw4jet 1 2,663 03-14-2021, 07:37 AM
Last Post: ludix
  PMOS test image: failed EG25 test broke modem fw MtnSk8 4 5,807 02-28-2021, 02:20 PM
Last Post: MtnSk8
  Is a Software update the same as instaling an updated image Word5 1 2,972 09-19-2020, 10:23 PM
Last Post: jmorris
  Incorrect Passphrase - FIx | How To Reinstall Image. NobodyNew1 0 2,154 09-02-2020, 09:30 PM
Last Post: NobodyNew1
