Android Rooted?
Hi Tommy_2Tall,
I'll try to answer all your questions as good as I can.
Tommy_2Tall Wrote:Maybe I've misunderstood something but will we be able to use Google Play Store, Netflix, Spotify, (other "DRM sensitive" apps) with a rooted device?
You will be able to use the most of the apps from Play Store.
Sure, there exist a few apps which will not work, if your device is rooted, but you can use the Xposed framework with "RootCloak".
RootCloak will hide "root" for specific apps.
- RootCloak (with 5.x and 6.x support) | Xposed Module Repository
I don't know how to install Xposed at the moment on the Pine 64, because I don't have a board yet.
The Google Play Store itself is really absolutely no problem with root.
Netflix is also no problem on a rooted device.
Tommy_2Tall Wrote:I was under the impression that a lot of apps from the Play Store will not run properly if you have a rooted device.
I can absolutely deny that.
Tommy_2Tall Wrote:It could be that the rooted devices that I've used in the past have been cheap noname tablets with limited support for Google Play and maybe those were not on some sort of "allowed/supported devices" list?
That COULD be the reason, but there is a solution Wink
The magic is inside the file "build.prop".
This files contains all relevant device information for Google Play Store.
It contains the model, display size, dpi, and so on.
There are some tutorials how to get your device compatible with the most apps.
Tommy_2Tall Wrote:So my main concern is probably wether there would  be a benefit to have an image which is NOT rooted in certain circumstances or if rooted is "always better"?
What do you expect from a "rooted" device?
What do you want to do with root?
It's useless to say "I want root!", but you don't know what to do with it.
So, please tell me more about your plans and I'll help you as good as possible.
Best regards
Julian
My forum topics:
• Create a WiFi hotspot on Debian 8
• Turn your Pine64 into a music server with mpd
• Adjust brightness of LCD on Armbian Desktop with 1 click
• My cases for Pine64 (acryl, lego & wood)
• Pine 64 - DACH - Facebook page for german-speaking Pine64-fans.
Android Rooted? - by monmoonmooonmoooon - 01-11-2016, 07:39 AM
RE: Android Rooted? - by tllim - 01-11-2016, 10:11 AM
RE: Android Rooted? - by monmoonmooonmoooon - 01-11-2016, 10:18 AM
RE: Android Rooted? - by tllim - 01-11-2016, 10:25 AM
RE: Android Rooted? - by leongzhi - 02-20-2016, 09:59 AM
RE: Android Rooted? - by minutesgrep - 03-15-2016, 01:57 PM
RE: Android Rooted? - by tllim - 03-15-2016, 04:18 PM
RE: Android Rooted? - by minutesgrep - 03-15-2016, 08:16 PM
RE: Android Rooted? - by minutesgrep - 03-28-2016, 08:17 PM
RE: Android Rooted? - by tllim - 03-28-2016, 11:31 PM
RE: Android Rooted? - by arpanj2 - 03-29-2016, 12:48 AM
RE: Android Rooted? - by minutesgrep - 03-30-2016, 04:41 PM
RE: Android Rooted? - by tllim - 03-31-2016, 01:18 AM
RE: Android Rooted? - by JulianM - 03-15-2016, 02:19 PM
RE: Android Rooted? - by Tommy_2Tall - 03-16-2016, 01:52 AM
RE: Android Rooted? - by JulianM - 03-16-2016, 03:05 AM
RE: Android Rooted? - by Ghost - 03-16-2016, 03:12 AM
RE: Android Rooted? - by JulianM - 03-16-2016, 04:00 AM
RE: Android Rooted? - by Ghost - 03-16-2016, 04:45 AM
RE: Android Rooted? - by Tommy_2Tall - 03-16-2016, 04:58 AM
RE: Android Rooted? - by JulianM - 03-16-2016, 05:00 AM
RE: Android Rooted? - by Tarjei85 - 04-11-2016, 07:10 AM
RE: Android Rooted? - by tllim - 04-12-2016, 03:40 AM
RE: Android Rooted? - by Tarjei85 - 04-12-2016, 03:44 AM
RE: Android Rooted? - by tllim - 04-12-2016, 04:29 AM
RE: Android Rooted? - by rahlquist - 04-12-2016, 05:42 AM
RE: Android Rooted? - by tllim - 04-12-2016, 08:00 PM
RE: Android Rooted? - by Tarjei85 - 04-13-2016, 12:29 AM
RE: Android Rooted? - by Tarjei85 - 04-16-2016, 02:01 AM
RE: Android Rooted? - by tllim - 04-17-2016, 08:58 AM
RE: Android Rooted? - by Tarjei85 - 04-18-2016, 05:24 AM
RE: Android Rooted? - by Tarjei85 - 04-21-2016, 09:38 AM
RE: Android Rooted? - by tllim - 04-21-2016, 03:45 PM
RE: Android Rooted? - by VeeKayB1 - 04-22-2016, 07:47 AM
RE: Android Rooted? - by tllim - 04-22-2016, 04:15 PM
RE: Android Rooted? - by VeeKayB1 - 04-25-2016, 09:57 AM
RE: Android Rooted? - by Tarjei85 - 04-22-2016, 12:13 AM
RE: Android Rooted? - by gschanuel - 04-25-2016, 09:43 AM
RE: Android Rooted? - by Tarjei85 - 04-25-2016, 09:58 AM
RE: Android Rooted? - by gschanuel - 04-26-2016, 09:32 AM
RE: Android Rooted? - by tllim - 04-26-2016, 01:52 PM
RE: Android Rooted? - by Tarjei85 - 04-26-2016, 02:56 PM
RE: Android Rooted? - by octopus - 04-27-2016, 01:48 PM
RE: Android Rooted? - by AA666 - 04-28-2016, 06:13 AM
RE: Android Rooted? - by hyperlogos - 04-28-2016, 11:12 AM
RE: Android Rooted? - by tllim - 04-28-2016, 12:36 PM
RE: Android Rooted? - by pinea64.edison - 04-28-2016, 01:46 PM
RE: Android Rooted? - by hyperlogos - 04-28-2016, 02:57 PM
RE: Android Rooted? - by AA666 - 04-29-2016, 10:28 AM
RE: Android Rooted? - by tllim - 04-29-2016, 10:38 AM
RE: Android Rooted? - by hyperlogos - 04-29-2016, 12:48 PM
RE: Android Rooted? - by JulianM - 04-28-2016, 01:00 PM
RE: Android Rooted? - by MrWizerd - 04-29-2016, 02:01 PM
RE: Android Rooted? - by tllim - 04-29-2016, 10:04 PM
RE: Android Rooted? - by MrWizerd - 04-29-2016, 11:00 PM
RE: Android Rooted? - by tllim - 04-30-2016, 12:29 AM
RE: Android Rooted? - by rakib-hasan - 04-29-2016, 11:22 PM
RE: Android Rooted? - by tllim - 04-30-2016, 12:35 AM
RE: Android Rooted? - by MrWizerd - 04-30-2016, 12:01 AM
RE: Android Rooted? - by rakib-hasan - 04-30-2016, 12:22 AM
RE: Android Rooted? - by tllim - 04-30-2016, 12:31 AM
RE: Android Rooted? - by rakib-hasan - 04-30-2016, 01:36 AM
RE: Android Rooted? - by MrWizerd - 04-30-2016, 01:55 AM
RE: Android Rooted? - by hyperlogos - 04-30-2016, 06:58 AM
RE: Android Rooted? - by JulianM - 04-30-2016, 12:23 AM
RE: Android Rooted? - by tllim - 04-30-2016, 12:36 AM
RE: Android Rooted? - by MrWizerd - 04-30-2016, 01:34 AM
RE: Android Rooted? - by ragnar - 04-30-2016, 09:59 AM
RE: Android Rooted? - by MrWizerd - 04-30-2016, 10:20 AM
RE: Android Rooted? - by Keex - 04-30-2016, 10:43 AM
RE: Android Rooted? - by octopus - 04-30-2016, 11:01 AM
RE: Android Rooted? - by Keex - 04-30-2016, 12:08 PM
RE: Android Rooted? - by ragnar - 04-30-2016, 03:28 PM
RE: Android Rooted? - by Keex - 04-30-2016, 04:00 PM
RE: Android Rooted? - by ragnar - 04-30-2016, 07:25 PM
RE: Android Rooted? - by Tarjei85 - 04-30-2016, 05:19 PM
RE: Android Rooted? - by MrWizerd - 05-01-2016, 12:43 AM
RE: Android Rooted? - by Tarjei85 - 05-01-2016, 03:33 AM
RE: Android Rooted? - by octopus - 05-02-2016, 08:04 AM
RE: Android Rooted? - by tllim - 05-02-2016, 09:44 AM
RE: Android Rooted? - by ragnar - 05-01-2016, 10:00 AM
RE: Android Rooted? - by Tarjei85 - 05-01-2016, 10:03 AM
RE: Android Rooted? - by Tarjei85 - 05-02-2016, 08:12 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 391,222 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,891 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,936 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 7,022 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,102 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,641 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,361 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 260,494 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,570 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,947 02-10-2019, 07:44 PM
Last Post: mmmarcus
