Screws broken off / General comment on inner Life of PB
The extra fine threads are very, very easy to cross thread.  !
The last two sets of new tires I purchased,    the person installing the lug nuts.
Put the lug nuts into the socket then pulled the trigger and jammed the lugs on !
  Several lugs had to be removed/cut off, using a Dremel tool as they were stripped in place and could not be removed.
Carefully turning the screws backwards until you feel the thread 'click' then turn the screw forward, as Arwen said is the safest method.
RE: Screws broken off / General comment on inner Life of PB - by bcnaz - 07-13-2020, 04:58 PM
Question Broken Camera ? angeloweb 2 1,352 11-28-2022, 09:47 PM
Last Post: angeloweb
  Broken Screen vxzero 0 1,370 08-26-2021, 09:02 PM
Last Post: vxzero
  Pinebook Pro broken eDP connector Ocawesome101 4 6,554 01-16-2021, 11:42 PM
Last Post: dsimic
  PineBook Pro Screws WZ9V 4 5,891 08-15-2020, 05:37 PM
Last Post: WZ9V
  Pinebook Pro Broken Hinge uncmonky 1 3,212 08-02-2020, 01:43 PM
Last Post: Arwen
  Broken Spacebar on PBP ISO Jeremiah Cornelius 4 5,066 01-29-2020, 10:15 PM
Last Post: Jeremiah Cornelius
  PCIe 4X socket for optional NVMe adapter -retaing clip broken . ndp 9 10,943 12-19-2019, 05:15 AM
Last Post: ndp
Question Screws and standoffs for M.2 adaptor Thra11 2 4,341 07-27-2019, 05:45 PM
